How would you handle this neighbor issue?
   / How would you handle this neighbor issue?
pacerron said:
Robert...
I would still like to know your method for controlling mold with such a lush canopy of leaves over the grapes. We Cut ours way back and still get mold as the summer progresses.
Ron
Are you positive its just a normal mold and not an actual disease?
   / How would you handle this neighbor issue? #132
Robert,
I just checked with my wife, who takes care of them, spraying and trimming.
She says they do fine until June or so when it usually gets rainy and wet around here for a period. Then the grapes begin to turn black and shrivel up.
A lot of them fall off. She has tried cutting the canopy way back this year as she read somewhere that the grapes were being shaded too much by the leaves. That is certainly wrong after looking at your great looking vines.
Our vines are Concord. We planted them about 15 years ago. The soil is primarily clay. The trellis runs north to south and we live on top of a hill so they get plenty of wind and sunshine. She trims them way back just as you described in your write up.
The supports are vertical wooden locust posts and high tensile fence wires for the 2 horizontals. We do get some grapes in the fall but not near as many as dry up or are pulled off by the white tail deer that roam this area.
I included a picture of what they look like now in your thread a few days ago.
We would appreciate any ideas you have as to the problem and solution.
Ron
   / How would you handle this neighbor issue? #133
Robert,
Ron
Can you describe your spraying plan........what chemicals when?
   / How would you handle this neighbor issue? #134
She says she uses "Daconil"
First spray when the grapes first show.
Repeates every two weeks till the middle of July.
If they start turning black she gives up.
Fertalizer 12-12-12
   / How would you handle this neighbor issue? #135
You sound like a nice guy. From your description I gather that they are not nice people. Why worry about it? Why spend time and money on their problem. Do what you're gonna do and forget about them. Of course, you don't want to inflict injury on them either. Grow your grapes and make some mighty fine wine.
Fertalizer 12-12-12
It sounds like black rot. I'm not familiar with daconil but elite 45df works well for me. I rotate by sprays though to help prevent resistance. I don't have a common set of sprays I use every year as each year is different depending on the weather. Rainy days are ideal for disease like black rot and phomopsis. I start my sprays at 1-3" shoot growth to prevent phomopsis and generally end up spraying every 10-14 days.
I don't make or even drink wine. I'm more of a juice guy.
   / How would you handle this neighbor issue? #138
Thanks for the description of your operation, it was an interesting read. I was curious, what do you use for herbicides that doesn't also kill the grapevines? It sonded like you're doing a foliar app? Are you targeting mostly monocots, or using something specific to annuals?
Before the buds pop and leaf out I use roundup. If the leafs are out i change to gramoxone and aim. Aim will burn the suckers off without any uptake into the vine. A lot of guys on gravel ground use solocam as a pre-emergent.
   / How would you handle this neighbor issue? #140
Robert,
Thanks alot. The leaves don't look as in this bulletin but the grapes sure do.
http://ohioline.osu.edu/hyg-fact/3000/pdf/HYG_3004_08.pdf
Probably too late for this year as the spray she has been using doesn't work.
We will get some of the other products and alternate their use as you suggest.
Ron
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
Kubota LX2620 (A53317)
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
