woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,155
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
So I am in the midst of putting a landscape plane together, simple landscape plane. I am really impressed with all the work done here but before I pull the trigger on my plans I wanted to get a concensus of opinions on a few things.
Angle or no angle blades. We discussed this earlier, seems that angled cut road ruts better but do not work as well on just flat level grading.
Body Weight. Make it heavy as possible for your machine....
Body Length. Hmmm No one has really discussed this from what I have seen. Shorter would be beter for hilly roads, right? Longer better for flatter roads? And what is that longer / shorter measurement? Mine will probably be based on available steel but....
Top Link... It seems to me that you would want the drag to float, I see all of the designs except one that the top link is solidly connected to the body of the plane. As I think about this, I wonder why. Wouldn't you want it to float, be able to angle up and down with a hilly road? I am thinking of a post that could bend and chains going to the rear of the plane. Anyone have thoughts on this?
Adjustablity of depth. Man, there is a couple of builds that are amazing, spin a lever and one end of the blade goes up. But at the end of the day, do those of you with fixed depth blades wish for adjustability?
Final leveler blade. On two designs I have seen a final blade (usually just angle iron) at the very back that is straight. I guess as a final finish? Needed or not?
FInally, I can pull a 6ft box blade pretty easily. Get it loaded, going uphill, and I drag down. I am debating wether I could do a 7ft blade (I would love an 8 to cover my tire widths but). Does a landplane take as much juice to move as a box blade?
Look forward to your guys and gals insights on this design......
Carl
Carl
