Brush mowing steep slopes
/ Brush mowing steep slopes
I looked again at Kents pics and don't see anything unacceptably steep for a two wheel tractor. It looks no steeper than my farm.
Bill,
Surprised that you haven't brought Grillo into the discussion. I'm thinking a Grillo G107D would be an alternative -- even if a used one would be almost impossible to find. How would it compare for using primarily front-mounted mowers?
I see what you mean, I've seen brush mower here in my neck of the woods mounted on the side of a tractor with sort of an excavator ARM and a brush mower to get the sides of the canals over here there similar to this but with a lot more reach and on the center of the tractor
A lot of the county road departments use something similar in East Tennessee, mounted on either a tractor (with a heavy counterweight) or old road graders, and hydraulically driven...
They use them to clear roadbanks, since they can mow both below and above grade...
/ Brush mowing steep slopes #23
Yes, the 107d would be a good alternative. I would have mentioned, but you all-caps'd "used" in your first post. Beings there's only about 1000 Grillos in the US, you're gonna have a lot harder time nailing a used 107d down vs. the used BCS models I discussed. Of course, you'll also find there to be a LOT more solid axle BCS machines available versus differential machines. Maybe a used 107d won't be any harder to find than, say, an 850...
This one here has the brakes on the steering column between the handlebars. They didn't put them on the right handlebar until January 2011 -
Walk-behind Tractor with tiller, cultivator and mower
The 11 hp 107d should be considered slightly smaller than the 13 hp 853. It'll handle any attachment an 853 can handle(and many more than the average BCS dealer carries), but generally takes one size smaller width. It also has a slightly faster second and third gear 1.8 mph vs, 1.7 mph and 3.3 mph vs. 2.7 mph.
Yes, I just can't swing the price of a new package right now, though the Grillo might make that a more affordable alternative than the BCS... I just can't swing $7k or more now for a package.
That appears to be a fair price for that Grillo package, given how clean it looks. Plus, I certainly think it looks better without the lime green hood that some have. It appears to have been well maintained, but the two most implements that likely got the most use are pictured -- the sicklebar and tiller. The tires show some wear, though, so this thing has certainly been put to use.
Is that the brake levers in the middle, over the yoke for the handlebars?
/ Brush mowing steep slopes #25
Hey all,
I forgot a big piece of information on the review of differential machines and it's too late to edit the original post.
The 737, 605, 830, and 850 have one big problem I've run into five times so far. The steering column liked to seize up in the position they're most commonly used. Four of my machines were used in the twin cities or northern Wisconsin as sweepers and were froze up that direction. the fifth was out of the cities and froze in tiller mode. IF you go look at a 737, 605, 830, or 850, be sure to check to see if the machine swivels from tractor to pusher mode. If it doesn't you're in for a job. Every one that I've broken loose involved taking apart the steering column, a 20 ton press, and a torch. The problem was fixed when BCS started building the 852/853.
/ Brush mowing steep slopes #26
Yikes, i wonder where a blade off of that would land?
/ Brush mowing steep slopes #27
Hey all,
You can add the 735 to that list also, but I caught it early and was able to get it loose with some spray lube and elbow grease.
Well I've got a lead on a 735 package, but I don't like the gearing/transmission on it, and it's priced a bit high IMO.
After my preliminary "elimination", I'm also now looking at two different Gravely Professional machines that have steering brakes. Without the steering brake, IMO, Gravely is out of the question...
Just to close this thread out, I ended up making a deal on a clean Gravely 5260 that has been repowered with a Kohler Magnum 12. It came with duals and steering brake, has less than 600 hours on it total, and about 200 on the newer engine. He put too big a deck (50") on it, and upgraded the engine to handle it about 10 years ago...
That slope is nothing like some I'll have to deal with, but it was the steepest he had, and shows how far away it is from the tipping point. I've picked up a 30" brush cutter for it, and will likely add a sickle bar at some point. Here's a slideshow of pics, if anyone is interested. Meanwhile, it will provide a starting point, and let me know what a 2-wheeled tractor is capable of...
http://www.flickr.com/photos/kentthomas/sets/72157629668699828/show/
/ Brush mowing steep slopes #30
That looks like a really nice machine. I think you're gonna need a lot more traction than turf tires are gonna give you. Is it easy to find and put taller lug tires on a Gravely?
/ Brush mowing steep slopes #31
I promise you that 4 strands of barbed wire won't contain goats. You'd need at least 12 strands, 3 per foot for 4 feet. Plus posts every 4-6 feet. When you think of goats, think Houdini.
I'd also listen to the guy warning you about trying to mow steep slopes. Very dangerous.
Thanks! It has spent almost its entire life mowing the same residential 1 acre lot.
Yes, they're easy to find, and there's 4-lug 4-on-4 hubs available from newer models to put taller wheels and tires, if more ground clearance is needed. These are the common 4.80x8s, and I happen to have one pair of new Carlisles on hand. There was an option for 7" wide wheels for the 18" tires on that 4-on-4 pattern. One of the reasons for choosing a Gravely in the end was the wide availability of "upgrades" and used parts and implements.
For example, there's conversion plates/kits available for bolting on virtually any of the newer OHV, pressure-lubed motors. A common conversion is to use the inexpensive Honda clones, then if you damage it by abuse (such as lack of oiling on steep slopes :laughing:) you can replace it cheaper than a rebuild of most engines...
That's a good looking machine, should serve you well. I haven't figured out what the third handlebar is for, maybe another attachment?
That's the steering brake. You push it to one side to engage the brake on the opposite wheel - the handlebar goes in the opposite direction of the way you want to turn. That brake gives you almost zero turn capability in addition to selective traction control, quite similar to steering using individual rear wheel brakes on a 4-wheel tractor.
That steering brake is almost essential for a tractor with duals, especially with a heavy attachment on the front or on sideslopes where the tractor will try to crab (moreso if it has caster wheels on the front attachment). You "drive it" with the left hand on that handlebar for steering, and the right hand on the handlebar for control. If you need to "man-handle" the machine, you use both normal handlebars...
You can lock the brakes using a parking brake lever, but otherwise normal braking is done by moving the direction control lever similar to braking with a hydrostat. You brake with the engine and transmission...
/ Brush mowing steep slopes #35
I Just hope you do not run into problems with
this unit and the degree of slope.
Your definetely going to need a several
pairs of spikes for your boots while mowing.
/ Brush mowing steep slopes #36
looks like a good setup for mowing keep us posted on how well it works I would be tempted to repower my Gravely to save hours on the power-trac
Thanks - will do. I hope to try it out (without the ags mounted) on some spots next week. I've located a 30" brush/weed deck for it locally so I'll install it and take it for a test run. After researching these old Gravelys more, the only real concern I have going into it is the splash-lubed Kohler engine. From the Kohler manuals:
That 23 degrees with the carb-side downhil is due to oilpan and crankshaft's oil slinger configuration. I'm really not worried about the machine's ability to stick to the slopes, because older L-model Gravely owner's manuals said their slope capability was 60 degrees, when running duals. That was, of course, the pressure-lubed Gravely engine.
In comparison, my PT-425's CH-25 is rated at 25 degrees on sideslopes (doesn't differentiate sides). So, I may end uphill mowing up and downhill with the Gravely in those areas with no runout or turnaround. I'll just have to wait and see... meanwhile I've ordered another set of ags and one set of chains but they won't be delivered and installed for next week's test run...
And, I'll learn how to operate it down in the hollow where it is safe...
/ Brush mowing steep slopes #38
It's my opinion that electric net fencing is the key to containing animals like sheep and goats in semi-permanent or temporary paddocks. We also use it on pigs, who are known to be persistent little escape-artists, and incredibly destructive. We have only ever had a failure when the fence itself was compromised (e.g. by a storm that washed out one of the posts). It's not cheap, but it's easy to set up, easy to move, and because it's electric, it's darn reliable.
Well, it's as reliable as your energizer, but that's up to you.
/ Brush mowing steep slopes #39
Sorry to resurrect an old thread, but I have pretty much the same problem as the original poster except my land (20 acres) is much more densely forested (I live on a mountainside, typical Oregon rain forest). I want to keep the mature conifers (mostly Doug Fir) and some other mature trees, but get rid of a lot of scrub brush/maple/oak.
A lot of that is too thick to cut with a mower, but I will still need to do something with what I cut up with a chain saw or brush cutter (looking into a Stihl Kombi and a chain saw for the stuff I can't cut with a mower) and I either need to cut it up for firewood or chew it up with a chipper. Either way I may have to pull out some of the wood to process it or process it on the spot.
There are trails through the forest and those are more or less what I want to clear, generally a lot of the scrub is on the flatter sections (still sloped significantly) and I want to clear a lot of that and use some of that land for terraced veggie gardens.
I could also use a log splitter and some of the other implements.
A four wheeled tractor just won't make it because of the slope and because I think there are places where such a tractor just won't fit between the trees that I don't want to cut down just to fit a tractor between them.
I don't require the tractor be used, but I do prefer a diesel. I am willing to spend money for axle extensions and possibly for wheel extensions if they would still fit between the trees. I think I probably want taller wheels because much of the terrain is rough.
I am leaning towards the BCS because it seems like it is more popular and there might be more implements for it?
/ Brush mowing steep slopes #40
I cleared the same terrain about the way you are thinking of. A Troy-Bilt Horse tiller with a rope is what I used to pull out the brush. Downhill loaded, uphill empty.
Brush 1.5 inches and up became firewood. I got tired of chipping the smaller stuff and made brush piles instead. Lots more birds around now.
Bruce
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
