Steering Wheel Removal
/ Steering Wheel Removal #1
MasseyWV
Elite Member
I'm trying to get the steering wheel off my Massey 135 tractor, but the jaws of my 3 jaw puller can't get a good bite due to the diameter of the rubber on the center hub.
Suggestions?
/ Steering Wheel Removal #2
Suggestions?
Back the nut out even with the top of the threads then take a hammer and hit the nut square on the top of the nut while some one else pulls up evenly on both sides of the wheel. works most every time.
I finally got the steering wheel off by using a hammer and a screwdriver to break away the rubber from around the metal hub so I could use my 3 jaw puller. Even then it was stubborn, so I had to apply a considerable amount of torque to it until I heard a "pop" as the steering wheel came loose.
Since I'm gradually restoring the tractor, the steering wheel is eventually going to be replaced with a new one, so chipping away the rubber around the center, while a radical move, isn't a problem.
/ Steering Wheel Removal #4
Another good way to try is to put a bearing splitter below the wheel and pull on that. The wheel should pop right off.
J
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
2023 Mercury Verado 350HP Outboard Boat Motor (A61574)
2023 Mercury...
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
2020 BOBCAT E50 EXCAVATOR (A64279)
2020 BOBCAT E50...
2012 Chevrolet Sonic Hatchback (A61574)
2012 Chevrolet...
