New receiver to avoid WDH setup?
/ New receiver to avoid WDH setup? #41
New trailers, especially this one, are tall. The trailer is sitting in my shop all leveled and if I walk into the ball mount it will hit me in the groin. They are really really tall. Getting out of the trailer takes a three step folding staircase and then a fourth full step before you hit the ground. This is a brand new 2012 Outdoor RV trailer made in Oregon by the same company that makes Artic Fox trailers and Nash. My last trailer was a nash and was much lower. Overall height is still under 12' but ground clearance is excellent.
The F350 has been lowered to F250 height by changing the blocks under the leaf springs. All springs and overloads are still F350 OEM. This dropped the hitch just over 2". The trailer's full tongue weight drops the rear bumper 3" and then when I set the WDH the bumper regains one of those inches for a total drop of 2" and just barely touching the overloads. It actually rides very nicely and level as set up. That crazy shank was 100$!
So the problem, Reg, is that the trailer ball mount is tall. Truck is fine. Trailer has max GVWR of 8200 so we're not talking a huge trailer. In fact, many folks report towing this size of trailer with half ton trucks.
Yes, the new travel trailers do sit very high..2 of my neigbors bought 2012 models and I can attest to that...In fact, one of them has a 2010 Dodge HD2500 with a 9" lift and 35's and he barely had to move his adjustable hitch to line up with the new one as opposed to his 3/4 ton 2001 Dodge CTD and a 2001 camper.
/ New receiver to avoid WDH setup? #42
The diameter does not differ. Its just after I started using top link pins I stopped seeing the elongating issue. I think its where the pin is deformed at the bend they put in standard hitch pins that does the damage. Noting scientific, just my observation.
I also cut mine down and drill a new hole so there is only maybe 3/16" or less of slop side to side when the lynch pin is in.
Chris, what about the locking pins?
/ New receiver to avoid WDH setup? #43
Not sure what you mean by this? I use the standard lynch pins like you would use on a tractor.
Chris
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
SAMSUNG ESPOKE REFRIGERATOR/FREEZER (A62131)
SAMSUNG ESPOKE...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-250...
Location Tampa, FL (A61567)
Location Tampa, FL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
