MF 2615 Fuel Filter Help
   / MF 2615 Fuel Filter Help #1
gary999
Cullman, AL
MF 615
2007 MF 2615 3 cylinder 49 HP diesel. The tractor will stall after running 15 minutes and will start again after letting it sit for 10 minutes. So I am pretty sure it is a fuel issue.
The owner's manual says to just fill new fuel filter with fuel and spin it on. It does not mention bleeding the system. Do I need to bleed it after changing filters?
The tractor is 3 hours away and my son did not get the filter numbers while he was there this week. What are the proper filters for it? It has dual filters.
The manual also mentions cleaning the tank strainer. Is it located where the fuel line leaves the tank?
I guess biocide is a no brainer especially since it sits for some period of time without being used?
Thanks in advance!
   / MF 2615 Fuel Filter Help #2
Thanks in advance!
I looked in the Wix and the Baldwin catalogs and Wix doesn't list the your tractor model and Baldwin says it doen't have filters for it. Guess you have to buy them at an AGCO dealer. I looked them up on the AGCO parts page and the numbers are 3905864M91 and 3905865M1. (Just google on AGCO parts and then enter as a guest.) You'll have to get them from AGCO unless you can cross reference them to another brand. Generally speaking ,the first filter canister is called a water separator/coarse filter and the second filter is a fine filter. They have drains on them.
You either have a clogged filter(s), a clogged tank strainer, or plugged fuel tank vent based on those symptoms. When is the last time you changed the fuel filter?
The tank strainer is located at the bottom of the fuel tank so you'll have to drain the fuel out and then remove the strainer. You can check for a clogged stariner by shutting off the tank valve and then disconnecting the fuel line on the tank side of the filter. Hold a container under the fuel line and openthe tnak valve. If you get a a CONTINUOUS gush of fuel than then the strainer is clear. If it 's intermittent or dribbles the strainer is clogged or the vent in the fuel cap is plugged. Repeat the process with the fuel cap off. If you now have good fuel flow, clear the plug in the cap vent. If the strainer is clogged drain the tank and remove the stariner and flush out the foreign material.
If you have good fuel flow at the tank discharge, reconnect the fuel line to the filter close the tank valve and disconnect the fuel filter outlet to the injector pump. Repeat the test again looking for CONTINUOUS full flow of fluid. If it dribbles or is much less than the previous test, replace the filters.
As far as bleeding, if your manuals say you don't have to bleed then you shouldn't have to.
If you live in warm moist environment you should treat your fuel with an additive that contains a biocide. Condensation will put water in your fuel and that will allow bacteria that live at the fuel/water interface and feed on the fuel making a snotty looking glob in the tank that can clog the strainer and the filters. After every use, fill the tank full to minimize condensation. Always open the drain on the water separator (first filter?) before and after using the tractor and drain any water off. If the fine filter has a drain, drain it at these times also.
Keeping the fuel system clean will help mininimize these problems. Always have spare filters handy. They aren't that expensives and dirty, wet fuel is the the major problem with warm weather diesel operation.
Jerry,
Thank you very much for the help. I went to all three sites but missed seeing it on AGCO. Your help will save me a lot of time when I go back down to the farm. Seems the 2605, 2615 and 2625 have the Simpson diesel (India) as opposed to the Perkins. Makes sense as my Dad was pretty tight with a dollar and I'm sure the Simpsons are cheaper.
Should I leave the tank strainer off if that is the issue and let the filters do their job? It reminds me of boat tanks where they have a screen filter on the pick tube that is impossible to get out. I always leave them off with no problems and let the Racors handle it.
With the part numbers you provided I found the filters on-line at $43 with shipping. I will be replacing them whether they are the problem or not.
Again thanks for taking the time to help.
   / MF 2615 Fuel Filter Help #4
Jerry,
Glad I could help you. Remember anytime you have these parts info problems go to the OEM website first. It's you best source of parts info for your machine. Make sure you put them on in the correct order.
I wouldn't leave the tank strainer off. It will keep some big stuff out of the fuel delivery system and prolong the filter life. Better to have the problem at the strainer because you can remove it, than to have it plug the fuel line to the filter and the filter inlet. Let the filters handles the small stuff. That's what they are there for. The strainer gets the big chunks.
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
Husky GHM105890 Cement Mixer (A49461)
Husky GHM105890...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
