X700 series owners w/Gas engine, how's your fuel usage?
   / X700 series owners w/Gas engine, how's your fuel usage? #1
Grateful11
NC
Our X720 seems to be burning better than a gallon and hour, more like 1.5 gallons/hour. We can get about 5-6 hours of mowing time out of a full tank. To us that seems like a lot. Is this about right? We have over 150 hours on it. We were hoping it would get better after it broke in but it hasn't.
   / X700 series owners w/Gas engine, how's your fuel usage? #2
Your mower has a 6.5 gallon tank, sounds like close to 1 gal /hr. to me. Alot depends on the grass you are cutting.
   / X700 series owners w/Gas engine, how's your fuel usage? #3
My priorities when buying my most recent tractor was that it be four wheel drive (of any type) and be a Diesel. Economy, economy, economy. Same reason both of our cars are Diesel although our next car will be all-electric.
   / X700 series owners w/Gas engine, how's your fuel usage? #4
I don't know which engine is in your X720, but my old 345 has a liquid cooled Kawasaki V-twin engine and it too has a voracious appetite for gasoline. I also burn over a gallon an hour mowing with a 54" mower. I'm planning on replacing it with a X740 and my only hold up is deciding whether or not the cost/benefit for a 7-iron mower is worth the extra money. I don't like the way the lush spring/early summer grass residue builds up under my present 54" mower. If the 7-iron doesn't have that problem, I'll gladly pay the additional $$.
Bill
   / X700 series owners w/Gas engine, how's your fuel usage? #5
I can't imagine that it is the same engine, but my X500 burns gas like crazy. Easily a gallon an hour - probably more.
In contrast, my diesel kubota b6000 has a two or three gallon tank and I hardly ever need to fill it up.
   / X700 series owners w/Gas engine, how's your fuel usage? #6
From another site, the big gassers burn 1.2 gph and the diesels 0.9; those are both at 3/4 load. Your consumption seems normal. I have not measured it but my 455 seems to get much better than that 0.9 rating.
Tim
   / X700 series owners w/Gas engine, how's your fuel usage? #7
1.2 GPH on my X729. 2011 with a 5.5 gallon tank.
   / X700 series owners w/Gas engine, how's your fuel usage? #8
Bill
If i'm not mistaken the 700 series has a deck wash feature that addresses that problem.
   / X700 series owners w/Gas engine, how's your fuel usage? #9
The deck wash port is worse than useless. It doesn't do a good job of removing the grass from the underside of the deck. It only adds moisture, resulting in additional rust.
   / X700 series owners w/Gas engine, how's your fuel usage? #10
My 425 burns about 1 gal/hour. So, I'd say your burn rate is about right.
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Rooster Weathervane (A55853)
Rooster...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2018 CON-WAY DOLLY (A59575)
2018 CON-WAY DOLLY...
