PTO shaft broke
/ PTO shaft broke #21
Is $160 more or less a normal price for a complete PTO shaft with slip clutch? I want to order ASAP, because it'll take a full 2-3 weeks to get here! Thanks
Actually, it's cheaper then most I've seen online (which have cost >$200 (US)).
Since it includes a slip clutch, it appears to be a real bargain.
Now, the downside...it's probably a Chinese import and likely a poor quality item.
Personally, I'd go for a better quality drive shaft, if at all possible.
/ PTO shaft broke
What is a good brand? Could you recommend a site?
/ PTO shaft broke #23
These look pretty decent:
PTO Shafts by Application
They're Italian manufacture. Price is about $170, but no slip clutch.
The only one I ever bought was at Tractor Supply...but that's in-store sales only.
The PTO drive shafts on both my mower and cutter are Italian...Caroni, I think.
Can you determine the manufacturer of the drive shaft you need to replace?
/ PTO shaft broke
There is nothing written on this PTO shaft. All I know is that it is original to the Kodiak cutter.
/ PTO shaft broke
Wouldn't it be better for me to order a 5 series PTO shaft instead of the 4 series that is stock for this cutter? As far as I see it, the only thing I need to pay attention to is that the ends are 1 3/8" 6-spline connectors. A 5 series shaft will be a lot stronger than the 4 series, correct?
/ PTO shaft broke #26
I don't know for sure if they are that much stronger...maybe not worth the extra money involved.
I suggest you call them and explain your situation...a phone call from Panama may not be cheap though...e-mail may be a better alternative.
/ PTO shaft broke
OK, thanks Roy. The website tells me the 5-series supports 60hp at 540rpm, and the 4-series supports only 35hp at 540rpm. I was thinking that since this shaft is in such bad condition, maybe my tractor at 75hp was too much for it. I will try to confirm this via email.
/ PTO shaft broke #28
Another question, before you buy the drive shaft...your Kodiak cutter, what is the gearbox rating for it?
If the cutter gearbox is rated for less then your tractor's PTO HP, you may be moving the load from a (relatively) cheaper component (the drive shaft) to a more expensive component (the cutter or gearbox).
Just something to consider...
/ PTO shaft broke
That's true. Better to break another shaft than the gearbox. Hadn't thought about that. Thanks
/ PTO shaft broke
I just found out that the PTO shaft for $160 wouldn't even work....it's way too short. My min length is around 60" and the max length on that shaft is 58". Lucky I didn't order that one! I am looking here now: La Magdalena PTO Shafts LaMagdalena shafts from Spain.... quality should be good. Price is a lot more at $240 though.
/ PTO shaft broke #31
Good thing you measured that before ordering!!!!
Another thing to consider is how both the cutter's gearbox and the tractor's PTO will be protected. Does your current PTO driveshaft have a shear bolt or slip clutch?
It should have one or the other and that should have prevented the damage to your (broken) PTO shaft (unless the shaft had been damaged previously, as you wrote in your first or second post).
If a slip clutch, it may not have been adjusted properly. If a shear bolt, it may have been the wrong grade.
If you have the manual for the cutter, it should tell you which grade bolt to use. If a slip clutch, it may even have instructions on setting the slip clutch.
Here's a Kodiak manual, but I don't know if it's for your model cutter:
http://www.kodiakmfg.com/manuals/Kodiak_Rotary_Cutter_Manual.pdf
If this manual does cover your cutter, you need a grade 2 shear bolt. Kodiak may even be a good source for the PTO drive shaft.
/ PTO shaft broke
If this manual does cover your cutter, you need a grade 2 shearbolt.
Thanks Roy. Just a little while ago I found this same manual online and realized that the part # the woman at Kodiak gave me might be incorrect. I measured my u-joints and it looks like I have a series-5 shaft instead of a series 4. What's more, the part # the woman gave me is for a PTO shaft with shear bolt, and I need one with a slip clutch.
I think you're right that the slip clutch was adjusted improperly, because I didn't noticed it slipping before....even when I went over a few big stumps. To be honest, I didn't even know this thing had a slip clutch before I broke the shaft.
I think I have found the correct generic part number now, which is CS53516. I will confirm this with Kodiak before ordering though.
/ PTO shaft broke #33
I don't know anything about that company, but seems like a good price to me.
--->Paul
/ PTO shaft broke #34
Weasler is the brand that tractor supply carries, Weasler has a good reputation in ag industry.
/ PTO shaft broke #35
Can't a place that fixes drive shafts take care of it? Even one that does heavy trucks (Class 8) should be able to fix it.
/ PTO shaft broke #36
Seems like new is now the best way to go. I wouldnt toss that old shaft away though. It may still come in handy some day. You may find some replacement tubing and new u-joint bearing to fix that one up better than new. In foreign countries, it never hurts to have a spare part lying around.
Heck when I was on a job in Peru, the contract called for a complete machine shop with 36" lathe so they could make just about any part needed to keep the LNG plant running. Most people dont have that luxury, but there are a few TBNers here that do have some nice machine shops.
/ PTO shaft broke
Yep, Kodiak gave me the wrong part number! I need 113-72SC, which is a series-4 with slip clutch.
I'll look into Weasler, thanks Tag01. I've definitely decided I want to order a new, good quality unit. This shaft I've got is in really bad shape.
I just realized you're from Arkansas, Gary. I was born & raised in Fayetteville.
/ PTO shaft broke
I have found a reasonably priced PTO shaft that would work for me at $208 on this site: A-CS43516, (Miscellaneous), Economy PTO,
Has anyone bought anything on this site before? Part number CS43516 seems to be a generic shaft that many companies carry, but this site has the best price.
Thanks
/ PTO shaft broke #39
Thanks
Based upon one of your previous posts:
Isn't this one too short too?
/ PTO shaft broke
Thanks Roy.... it's true, this one is also short. I need something with a collapsed length of 56". That means spending $380 + shipping + import duties for the original Kodiak shaft, or $250 for a heavier duty series-5 or 6 shaft. I think I'm going to go for a heavier duty shaft...
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
TR 23 QA Mini Trencher (A64127)
TR 23 QA Mini...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
