PTO shaft broke
/ PTO shaft broke #1
trisr
Panama
new holland tt75
I have a Kodiak Rotary Cutter Medium Duty and I just broke the PTO shaft. See picture. I live in Panama, so getting parts takes a while. I want to know if I can weld this, or if I should buy a new part. If I need to buy a new part, does it need to be the whole PTO shaft or just the sleeve that broke? Where is a good place to buy? Sorry for all these questions. It's my first tractor and I have only used it for 30 hours. I bought everything used. I think the PTO shaft was already damaged, because I was only cutting grass when the thing broke!
Thanks
/ PTO shaft broke #2
You should be able to take it to a machine shop where they can replace the shaft.
/ PTO shaft broke
Thanks for your reply, abeal. Is this a universal shaft, or unique to Kodiak implements? Is there a place online where I could just order a new shaft?
/ PTO shaft broke #4
No this is a standard pto drive shaft just make sure your measurements on end that goes to spline on cutter is correct, also the length. You do not have to go to Kodiak to match it up, however it does look a shorter then it should be for the amount of shaft engaged into one another.By looking at picture it only looks like it was engaged with the other half about a 3" should be about 6" or so if I remember correctly.
Devildog
/ PTO shaft broke #6
G'day that has failed due to being too short, you need a longer shaft it should be engaged a foot or better when running. Just got to make sure that it does not bind up when you lift the 3pl. I always try to get the machine on the linkage and lift it till the pto shaft on the tractor and the shaft on the machine are level ( at their closest points ) and cut the shaft so I have got about 1" clearance when I uncouple the shaft this way I know I have enough clearance when the shaft is attached.
I would not weld that I would replace, there are alot of Pto shafts available aftermarket just measure up and go with one of them
Jon
/ PTO shaft broke #7
If you can find the exact same shaft configuration and size, you could grind off the weld at the U-joint, remove the old shaft and add a new one. It does appear to be a tad short so new measurements are in order to make a new one at least 3" longer from the looks of it, but do the measurements as already posted.
The whole shaft looks a bit undersized. If I were to buy new, I would go with a bigger, slightly more robust unit. Just have to make sure the end that attaches to your mower and tractor are the same. Tractor should be std PTO sized but mower gear box shaft might be any size so you would have to mike that to get accurate sizing. It needs to fit snugly.
You might find a machine shop that could cut both ends from the u-joints, put in larger or just heavier wall shaft material on both ends for less than you can buy in USA & ship to Panama. I dont know what you have locally, but most foreign countries I have worked (I have worked in a lot of them too) are very resourceful in fixing things to work as good or better than the original. Americans may make fun of some of the things that are done that would make an OSHA inspector faint dead off, but they get the job done and most times are able to walk away unharmed.
/ PTO shaft broke
Thanks for the reply guys. I will see what a machine shop can do for me before I order any parts from the USA. Shipping & importation costs are expensive.
/ PTO shaft broke #9
The machine shop would probably have to replace the shaft...actually, both the male and female shafts.
Due to the slip fit (so the drive shaft can telescope) and the rotational stresses, I don't think any kind of weld repair would be adequate, or safe.
/ PTO shaft broke #10
I think you may have misread my post ROY, I was not suggesting that they cut the shaft and butweld it, but to remove the whole shaft and weld a new on to the U-joint yoke and make it longer and heavier in the process. It looks to me like that shaft is pretty weakly made from likely twin tubing pieces rather than a pieces of solid bar stock for the male and heavy tubing female section.
I'm sure the local shops can fix him up with a replacement shaft material welded on to his u-joints that will work. He just needs them to make it a bit longer this time so the overlap is more
/ PTO shaft broke
I have been shopping around in Panama and the cheapest complete PTO shaft that I have found is $360. In the USA, you can buy them for $100-150, but shipping would be around $70 and taxes another $50 and I would need to wait 3 weeks. These are the times I miss living in the USA!
EDIT: By the way, they don't sell just the tubing here. Just complete PTO shafts.
/ PTO shaft broke
I understood your idea, Gary. The problem is finding a good machine shop here in Panama. I have yet to find someone who does acceptable work. The last time I had something welded I was not at all impressed!
/ PTO shaft broke #13
I can't tell for sure from the pic, but often that type of shaft is pinned, or riveted into the universal joints at both ends. That is fairly easy to take apart & put together.... Even a poor machine shop should be able to get that right.
You would need to find a male and female tube of that size, and have both replaced. The expensive part of a pto shaft is the univeral joints - yours are probably good so no need to replace everything, just the tubes. The tubes come in standard lengths, you cut down to what size you need.
As mentioned, your problem could have come from a pto shaft too short. They need to overlap a fair amount, but not be so long as to bind up when lifting the implement. (That causes many expensive parts to break...) I would measure out if you can use a longer pto shaft.
Since the female tube is so wrecked, be sure to replace the male tube as well - it will be wobbled out & poor, and these shafts need to slip easily and not bind up at all.
--->Paul
/ PTO shaft broke
That's true. A pin does hold the tubes to the u joints. If I can find the tubes somewhere, then I can replace them pretty easily. I will need the plastic shield too though....it broke at the same time the tube broke.
/ PTO shaft broke #15
Yeah, I probably did misinterpret your post (as far as the welding).
Considering the costs involved, even with the shipping costs, replacement of the entire PTO drive shaft may be most cost effective. There may not be much farming or tractor use in Panama, but I'm sure there is in neighboring countries. Import duties may just be a required cost, however.
/ PTO shaft broke #16
Yup - those are pretty easy, punch pin out, hammer old shaft out, cut new shaft to length, hammer (gently so as not to deform tube) new shaft in, drill the hole, and put pin back in.
There are I think 3 common sizes (thicknesses, or hp ratings) of that type of tube, you need to get the right one.
I think only about 3 companies make shafts any more, so it will be one of 3 different designs, as well.
But should be a fairly common item.
The plastic covers shoulsd be available where the tubes are too.
--->Paul
/ PTO shaft broke
I'm still searching for tubes + plastic covers. If I can't find any here, I'll probably buy the whole PTO shaft as Roy suggested. I hope I can find the tubes though.... the extra cost doesn't bother me quite as much as the long wait for parts to arrive.
/ PTO shaft broke
OK, well, I just pulled the slip clutch off and realized that the nipple where you apply grease is missing and the u-joint is about to give out. The front u-joint isn't in great shape either. The previous owners of this thing really didn't take care - cut the PTO shaft too short and never applied grease. Also, I think this cutter is rated for a 40hp tractor, and mine is a 75hp. I need to just replace the whole PTO shaft with slip clutch.
Do you all know where the best place to buy shafts is? Is Agri supply OK?
/ PTO shaft broke
Is $160 more or less a normal price for a complete PTO shaft with slip clutch? I want to order ASAP, because it'll take a full 2-3 weeks to get here! Thanks
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
1994 New Holland 580 Square Baler (A63688)
1994 New Holland...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
