Fuel Consumption GPH
/ Fuel Consumption GPH #41
My TC33 (33hp but hydro trans) on avg consumes .5 gal per hr. Ive recorded that over numerous tanks of avg use, both FEL work and lawn moweing with the MMM and also for the 40hrs we put on it digging a new drain feild useing the backhoe. (20 gal of fuel used, tracked and recorded)
Durring heavy work, heavy brush hoging, bottom plowing Ive seen that rise to 1gal per hr but im at high idle (2400rpm) and often hearing the engine pull down for extended times. (again tracked and recorded)
I would be really happy to average .5 gph for a tractor bigger and heavier than mine is. Diesel here is still around $4.10 per gallon.
/ Fuel Consumption GPH #42
As a rule tractors have the best torque and specific fuel consumption around the PTO speed. Look at the power, torque and consumption curve for you particular engine and you will see that the PTO speed is just a hair past of maximum torque point.
/ Fuel Consumption GPH #43
My JD is so economical that every few hours I have stop and drain a little out!!:thumbsup::laughing::laughing:
/ Fuel Consumption GPH #44
Check to see if your exhaust sytem is routed too close to the fuel tank which will cause expansion and overflow.....:laughing:
John Deere 755 (A64119)
John Deere 755...
79" X 48" TAILGATE (A64280)
79" X 48" TAILGATE...
UNUSED WOLVERINE FORK FRAME (A64281)
UNUSED WOLVERINE...
TEST YOUR BID BUTTON! (A64279)
TEST YOUR BID...
(3) 5 LUG TRAILER DROP AXLES (A64280)
(3) 5 LUG TRAILER...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
