Comparison B26TLB vs. B7800
/ B26TLB vs. B7800 #1
magicheater
central Wisconsin
Kubota B7800, B26 TLB
While contemplating downsizing/consolidating I ran into the B26TLB. I was impressed by the loader capacities and the backhoe digging depth/height. I did not see that Kubota had not included the HST+ as in the L45TLB and wondered, why not? The 3 PT Lift was the same, Engine/PTO HP more for the B7800 and Loader capacity more for the B26. I am drawn to the package but would expect it would be superior in every way than to a stripped down older model.???......:confused2: Please comment!
/ B26TLB vs. B7800 #2
First off, no HST+ on these models because it is a B-series. None of the other B's have it yet and probably won't in the foreseeable future due to the cost, complexity and size requirements of that system. Since the L45 is built on the Grand L platform it was natural they included it in that tractor.
As for the comparison between the B26 and B7800, having used both extensively (well, a B3200 and B26) here's my take:
The B26 is great around the job site and doing other utility related tasks. The loader is impressive for a B-series (in fact I think it out specs the L3200/3800) and the hoe is also very nice. You truly get a lot of earth moving performance in a small package. Of course, the skid steer quick attach is also nice along with all the hydraulic options, position control 3pt hitch, etc.
The B7800/3200 is much better in the power department. Whenever I use a B26 the power difference is quite apparent. Things that you wouldn't think of as a problem with your B7800 really slow down the B26 (like going up a steep hill in Medium range with a full bucket). PTO work is also a noticeable difference. My B3200 handles a 5' bush hog in most every condition with ease, IMO 4' would be better for a B26, but then it doesn't cover your tracks. Another thing is the B26 feels a good bit bigger, especially in the woods. With the wide loader frame, fixed canopy, and large hoe hanging off the back it can be difficult to maneuver in the same spots I take my B3200.
For me the extra power of the B3200 and removable loader is more beneficial than the extra loader and BH capabilities. I use mine for as much farm related work as I do construction and for that the B3200 is a better option. If I were using it for 90% construction, landscaping, trenching, etc work I'd definitely spend the extra $$$ for the B26. The B26 is a very nice package, and I sure wouldn't mind having one. Aside from the above mentioned reasons, the other reason I went with a B3200 was of course cost, with the B26 being about $7500 more (both similarly equipped)
/ B26TLB vs. B7800 #3
well put by Verticaltrx. not much i can add. i will say, i own a b7800, seen the btlb series, and extensively looked at the b3200 & b3300su. all good tractors. i am very happy with my b7800. does things that i never thought a tractor of that size could do. as for the tlb series, i have been told they have far superior hydraulic systems/power, as they are more geared for contractor work,=hence the better loader/back hoe specs.
32ft Flatbed Equipment Trailer (A64553)
32ft Flatbed...
2021 BOBCAT T76 R-SERIES SKID STEER (A65056)
2021 BOBCAT T76...
CAT D5N Straight Blade / C-Frame (A68134)
CAT D5N Straight...
More info coming soon. (A64557)
More info coming...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
