Help with 400x Leakdown
/ Help with 400x Leakdown #1
trook
Gold Member
North Central Mississippi
JD 5075E Cab
I have a JD4320, 370hrs, with the 400x FEL. I noticed when disking last week, that the curl portion of the fel seemed to be leaking down as i was disking. The overall height may have been leaking down as well. I found myself increasing the height on the fel every few minutes.
Tonight, I left the FEL approximately 4ft high and returned about 4 hrs later and the fel was on the ground. Obviously, this is not right. Can anyone give me pointers on how to find the problem? The fluid level is fine and I don't see obvious signs of leaking fluid on the ground.
Oh yeah, I changed the hydraulic fluid and filters about 10 hrs ago. I didn't notice an immediate change in FEL leakdown, but it was probably there... After changing the fluid, are you supposed to "bleed" the system somehow?
/ Help with 400x Leakdown #3
Not even a few drips of oil? Somethings wrong with the cylinders? But for that young of a Deere nothing should be wrong...
/ Help with 400x Leakdown #4
Many people complain about the 200 and 300 series slowly leaking off when running as well. While I done like that myself, apparently it is normal.
I don't know if there is supposed be something special about the 400 series but for the FEL to drop down is normal in most equipment when not running.
/ Help with 400x Leakdown #5
Also many people complain about the 200 and 300 series slowly leaking off when running as well. While I done like that myself, apparently it is normal.
/ Help with 400x Leakdown #6
In my opinion, I don't think they should leak down at all. My neighbor has an Kubota tractor and his loader will stay up all day long. During deer season, he will hang his deer from the bucket and gut and clean it with no loader leak down at all. Hate to say it but, it must just be with JD loaders. The 300x on my 4210 would leak down fairly quickly. Dealer told me that was normal. Now the 300cx on my 3320 doesn't seem to have this problem. I can leave the bucket up overnight and the next morning its still up. Makes no sense to me.
/ Help with 400x Leakdown #7
I had a bx24 before, it didn't leak down for the first year, but it started after that.
I wouldn't expect such a feature in a CUTS.
One problem I may have caused, but not sure, occurred last weekend. I have a "thumb" mounted on top of my bucket and the top of the bucket has flexed some due to the torque of the thumb. The only way I have found to bend the top of the bucket back to its original position is to "dump" the bucket, place it against a tree, and drive forward in A1 to push the top of the bucket back into its original shape.
I know this has some risks, but it is the only way I have found to bend the bucket back to its original configuration because of the nature of the bend and the shape of the bucket.
I know some leakdown is normal, but I've never experienced leakdown like this, especially when the tractor is running.
Could I have busted a seal or something?
If so, how to I inspect it, and what tools do I need?
/ Help with 400x Leakdown #9
You may have an "internal" leak in one of the cylinders. I had a problem with my steering ram cylinder a couple weeks ago, the tech said the leak was internal. Said he could have rebuilt it but switched it out instead. Been fine since.
/ Help with 400x Leakdown #10
I had a 1963, 2010 and the FEL would stay up off the ground all winter long. My 2006 CX200 dropped from day one, both raise and curl. I complained to my JD dealer and was told that Deere accepts up to a 7" drop per hour leak rate through the cylinders.
/ Help with 400x Leakdown #11
7"s per hr seems like a lot. I think JD is using that to escape some warranty issues. There's really no excuse for a good spool valve & cylinders to leak that much especially with no load in the bucket.
/ Help with 400x Leakdown #12
Amen.. 370 hours and having to constantly adjust the loader when working in the field?!!?
That ain' right!
AKfish
/ Help with 400x Leakdown #13
From the chart I saw on maximum acceptable leakdown rates, the largest numbers for the 400x on a 4000 series tractor were 2.4 inches per hour on the boom & 5.10 inches per hour on the bucket (curl I assume...).
FWIW
Nick
/ Help with 400x Leakdown #14
That is ridiculous. Especially when it is running. Sitting dormant is one thing.
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
JCT Skid Steer Tiller (A64047)
JCT Skid Steer...
2007 KENWORTH T800 CRANE TRUCK (A63569)
2007 KENWORTH T800...
80003CFL (A61568)
80003CFL (A61568)
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
