modified exhaust
/ modified exhaust #1
Ginormous
Gold Member
Dayton, Ohio
Yanmar YM2210
A recent thread had a link to a for-sale ad with a Yanmar that had a modified exhaust. I just found another one. Here are pics from both. I like the idea of the exhaust blowing out the back instead of up right over the hood... What do you all think about this exhaust mod?
/ modified exhaust #2
I thought I recalled even a factory option where the exhaust ran downwards and not up. In the right instance it could be of value.
/ modified exhaust #4
I have posted it before but mean no harm by doing it again for new members. I have run mind forward, down and out and it works quite well for me. I do a lot of mowing under low trees and the sticking up muffler just won't work for me.
/ modified exhaust #5
I have my muffler in the horz position facing forward, with a auto part store add on chrome 90 degree tip. I have it this way so it won't hang up on the low branches, and rain water is not an issue. (we never have rain up here in the PNW):). But I like the idea of running it back and under. We have a local muffler guy that does custom work and will see what it would cost to run it aft. I know that I would have to order a new gasket from Hoye to flip the muffler 180 to the rear. 5.19 for the gasket, plus shipping. Will add that to the next filter order.
/ modified exhaust #6
You're right Pete.....no rain up here in the PNW.....haven't seen any rain since the last time I looked outside. As for the muffler......mine is where it supposed to be.......a little diesel smell makes me happy and content! :confused2:
/ modified exhaust #7
Totally true about no rain in the Pacific NW. :laughing:
I have seen that kind of muffler on a John Deere 2040 but the disadvantage I can see is when you hook up implements to the 3 point hitch you will have to breathe in all that exhaust in the process. I always left my Yanmar running so I could reach forward and adjust the hitch up and down (before I got the imatch) so i didn't have to wrestle with the implement too much. I also could see that hot tail pipe running through dry grass in the summer running the risk of causing a brush fire so I would also keep that in mind. Otherwise i don't know of too many other issues, possibly additional heat radiating from it in the summer but on the flip side that may be an advantage in the winter months. :)
/ modified exhaust #8
It's nice to keep one foot warm in winter, but it gets _awful_ warm on the foot in summer....
Hooking up implements or working with a log splitter, chipper, etc you get a good long wiff of exaust - funny how much time you spend back there & don't realize it.
We had it on a gasoline tractor, and were moderately concerned about starting a grass fire. Proably not so bad with a disel, but we would leave a brown spot if we were stationary for too long in one spot - depends on where you aim it out back I suppose.
All in all we hated it, dad changed it pretty quick. But that was us with that gas tractor, can be different for what you have....
--->Paul
/ modified exhaust #9
My stack is just like you see on ebay or at Hoye for replacement mufflers. It has the angled 90 turn at the top of it. Mine is facing foward right now but am going to point it out to the side to decrease the exhaust in the face a bit more. But seriously i dont really smell it at all unless there is a stiff breeze im my face. It goes upward most of the time and am going so slow it seems to disipate before i smell it. Maybe im use to it?? Running a weedeater or lawnmower leaves me more concious that im smelling the exhaust than the tractor.
And my feet are already hot enough from then engine heat blowing backward onto them, exhaust heat would be horrible!
/ modified exhaust #10
Mine doesn't hardly smoke. So I prefer to have all the Diesel fumes Dispersed by the open air and I hardly can smell anything. And thats even now after I quit the cigs. :D The most load I ever put on it is with the tiller. Here's a pic. of the exhaust at it's worst under a load and that when I just start a pass with the tiller and load it up. It not a problem as you can see for me and if there was mine would get ran out the back with a Quick Hitch setup. ;)
/ modified exhaust #11
mines straight up and about facing between 1 & 2 o clock. i never get it in the face but it barely emits anything anyway. only that very faint puff on acceleration. then my YM4 on the other hand, the fumes from that thing nearly knock you out. you can see the "blue haze" out the exhaust
/ modified exhaust #12
I think whatever works in your situation is the best way! :thumbsup:
We all have different obstacles and requirements nothing wrong with modifying it. Now doing it nice that is where I would be super critical it would have to be pretty and functional and not be in the way later when I do repairs etc etc thats me. Pic 1 looks like a good instal fwtw.
Mine is straight up with a flapper that directs the smoke forward and up and wouldn't work any other way with my requirements at this point in time.
jmho I think a good whiff of ulsd smoke is a good thing occasionally it makes me think cheap efficient horse power. :laughing:
edit: its the choking dust cloud that seems to find me and stick with me when I am tilling a big garden is what I would like to modify! :)
/ modified exhaust #13
Horizontal forward. It's well tucked into the loader arms where I can't snag it in the orchard.
I turned the YM186D exhaust forward like this too, as soon as I brought it home.
I've had good luck re-using the gasket. I have a new gasket on the shelf that I didn't need for either tractor.
/ modified exhaust #14
I did mine like California, Makes it alot easier to cover up when not in use.
/ modified exhaust
Were you able to just unbolt, turn it 90 degrees and rebolt it back on?
/ modified exhaust #17
If I was turning mine for some reason it would be forward. I spend too much time in the back hooking stuff up like most probably do.
/ modified exhaust
I'm thinking that it would be best toward the front too. I need to go stare at it for a while and decide if I want to do it... :D
/ modified exhaust #19
That is what I call a nice instal! :thumbsup:
Looks like Yanmar probably had that configuration designed in thats a clever use of parts and space I think anyway.
/ modified exhaust #20
Guys think about it :confused: Not much of a choice. If you point it backwards Like I would with a Quick Hitch your be adding a Tail pipe. Back and no exhaust pipe you "Will be Wiffing it up" :laughing: Point it down how long will that Last :ashamed:
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
2001 Top Utility Trailer (A64912)
2001 Top Utility...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
2012 CAT D60-6 GENERATOR (A67714)
2012 CAT D60-6...
2017 Freightliner M2 106 Passenger Bus (A66736)
2017 Freightliner...
1991 American Pride APE2-6 Electric Cart (A66738)
1991 American...
