Backhoe Bucket Tooth Wear
/ Backhoe Bucket Tooth Wear
Jim,
I finally got around to ordering my fork teeth yesterday and was told they are back ordered. So now I wait longer.
hugs, Brandi
Brandi, the teeth I got from them have been excellent. I've not worn out the first set I installed. They sell quality products. I'm sorry you have to wait a bit on the backorder.:(
/ Backhoe Bucket Tooth Wear #62
I know this thread is old, Jinman, but did you ever try the other clamp stile pins?
Reason for me asking is because I recently bought a Case 580 Super M Series 2 and I started cleaning ditches and lost my first tooth on that maschine after about 10 engine hours. It had new teeth installed by the dealer, when I bought it and it has those clamp stile pins in it. So far I am not so impressed with them. The soil around here has a lot of rocks and big boulders in there. Anyway... so far my plan is to get bolts and locking nuts...
I have bolts/nuts only and have no problems with teeth except I probably am due for a new set. I bought enough for another couple of replacements. Since bolts are so cheap and easy, I doubt I'd ever even give the pins a chance. Every hardware store in the world has bolts, but not those specialty pins.
/ Backhoe Bucket Tooth Wear #64
I am busy ripping out tree stumps at the moment with my Case 580 Super M. I keep losing my bucket teeth. So I replaced the split pin with a grade 8 bolt, washers and locking nut. So far the split pins hold up 10 times better than the bolts with locking nut. Today I broke 3 bolts and lost one tooth. And that is every day like that when I work the machine all day. 2 or 3 bolts are nothing a day. I am just about thinking to weld them on. :(
On my backhoe the tooth stub takes all the pressure. The bolt just makes sure the teeth stay on the stub. I've dug in hard material and rocks, but never had a problem with the bolts. I wonder if the Case bucket is made slightly different?
/ Backhoe Bucket Tooth Wear #66
I lost one on the JD 310B but they were all really worn. Found four replacement teeth for $6.50 each. The old ones had been welded on upside down. The shop welded the new ones back on correctly. So far so good.I am cutting a lot of roots so I can push over trees but we do not have rocky soild.
/ Backhoe Bucket Tooth Wear #67
Not that I can see... Split pins are 5$ a piece, but surely worth it to me.
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2021 John Deere 6110M Tractor (A63109)
2021 John Deere...
