New receiver to avoid WDH setup?
/ New receiver to avoid WDH setup? #21
Most of the times I have seen the pin hole elongate its due to the pin design. The standard pin with a bend in the last 3rd are the biggest culprit.
I guess I'm just a bit lost. How do the pins differ? The portion of both the top link pin and standard hitch pin that goes through the receiver is round metal. Unless the standard hitch pin is a slightly smaller diameter, but one would think that hitch manufacturers would build their products to work with standard pins.
/ New receiver to avoid WDH setup? #22
The diameter does not differ. Its just after I started using top link pins I stopped seeing the elongating issue. I think its where the pin is deformed at the bend they put in standard hitch pins that does the damage. Noting scientific, just my observation.
I also cut mine down and drill a new hole so there is only maybe 3/16" or less of slop side to side when the lynch pin is in.
Chris
I would not feel confident that the small shoulder on the fixed end of that pin would keep the pin in place. Too much bad can happen if that pin decides to fall out.
I have never liked the simple hairpin style of retainer clip on the standard issue bent pins so I exclusively use the locking style that have a big head on one end and a big locking head on the other.
So the switch was made. I tossed the factory 500/5000 lb receiver from my F350 and installed a curt classV receiver with 2" hole rated for 1500/15000 without a WDH. The new hitch cost 211$ and lined up perfectly with existing holes, the same holes that the OEM hitch used. Yes, the new receiver is built tougher with much thicker steel and more of it.
This is a safety upgrade even if all you plan to do is tow within the OEM hitch's ratings. That much more margin.
We'll see how it does towing the tractor without a WDH.
/ New receiver to avoid WDH setup? #25
They make good stuff and the paint is first rate compared to Reese and some of the other big names. Just make sure your balls and draw bars are rated for the task.
Chris
/ New receiver to avoid WDH setup? #26
This is just an observation, and I will TRY to keep it to things I know, and hopefully everybody will be NICE when they shove these observations down my throat...
My 2000 F350 has a tow rating of 20K, but in the fine print it says that is 5th wheel rated, all other is limited to 10K, so apparently I can tow 10k from the bumper or the 2" receiver. Now since the truck manufactor limits the bumper to XX pounds, that only makes sense to use the receiver hitch which is limited to 10K. Now if I want to haul 10001 pounds using the receiver, all I have to do is upgrade to a higher rated receiver, make sure the ball and pin are rated to that amount and start hauling, RIGHT?
The problem I see with that idea is simple. The D.O.T, law enforcement, and especially the ATTORNEY'S will still see the truck as a 10K max receiver truck, with some added safety capacity, but it is still a 10K rated truck. As long as the manufacturer rated it as that, and right up to when somebody upgrades the truck (not just one piece it) and pays to have it certified, which includes all of the parts, that it is now capable of hauling more, the lawyers and law enforcement will still nail you when stuff hits the fan. They will argue that nothing changes the manufacturer's rating except either the manufacturer or some engineering firm with way too much time and money on their hands. All I am saying, is that changing the hitch to a higher rated hitch isn't going to increase what the manufacturer rated the truck at, even if the component manufacturer says their hitch is rated at XXX more than the manufacturer.
David from jax
/ New receiver to avoid WDH setup? #27
David from jax
I would have to agree with that from a legal/liability perspective.
/ New receiver to avoid WDH setup? #28
Not quite the arguementitive post I was expecting, but thanks for the support!!!
David from jax
/ New receiver to avoid WDH setup? #29
David from jax
I'm not sure what there is to argue about based on your post, I think you're spot on...You can turn a Tacoma into a Kenworth capacity wise I suppose, but it's still a Tacoma.
I used to pull a BP TT that weighed around 8500# with a 91 and 97 reg cab Chevy 4x4 SB 5.7...Not sure what the OEM tow rating was (I was in my 20's and didn't care, I do now) but I'm certain that I was way over limit...If something would have happened, and I was over, I would have been in deep doo-doo I'm sure...The State Police checked the rig over in a "safety" checkpoint once and didn't say a word though.
/ New receiver to avoid WDH setup? #30
The issue here is the manufacture put a hitch that was well below the trucks BP capacity. I see it all the time and broke a hitch in a F250.
I agree putting a bigger hitch on is not all its about. He is just getting a hitch that is capable of taking advantage of the trucks capacity.
Chris
/ New receiver to avoid WDH setup? #31
Chris
Works for me, but wanted to make sure others reading this post didn't get the wrong idea about adding a bigger/better hitch to increase vehicle capacity above and beyond the manufacturer's rating.
David from jax
I have no intention of exceeding any of the truck's ratings. Never did, check the thread title. The goal is to be rid of the lousy Ford receiver along with its requirement that even a small 5001 lb trailer only be towed with a WDH system.
DP, I've chosen the hitch and ball from etrailer that will match or exceed the receiver's ratings. I am now trying to select the proper drop height since I will not be paying 200$+ for an adjustable height hitch setup.
I'm not sure I buy into this 10k max trailer rating. Trailer ratings are generally a marketing BS number not to be confused with actual GCWR, GVWR, and GAWR type ratings. I don't have 10,000 written anywhere on my door sticker.
Is there something special about Fords or is it like the other trucks where GCWR minus truck weight determines allowable trailer weight?
/ New receiver to avoid WDH setup? #33
I have two concerns.
The first would be that using a weight distribution hitch adds weight to the front axle of the tow vehicle which aids in braking.
The second may be a non issue with a one ton frame but, the reason the hitches are rated higher for a WD setup is because the bars torque the ball mount in the reciever tube which adds weight to the forward most bolts that are securing the hitch. The leverage and torque direction is actually opposite as opposed to not using a WD hitch. The frame of the truck is stronger towards the axle vs at the rear end of the frame. Like I said, may not be an issue with your frame but there are reasons for the difference beyond just the hitch.
Jeff
/ New receiver to avoid WDH setup? #34
I still feel you will miss the WD hitch once the roads get bumpy. You can put a 30k lb pintle hitch on the back of that truck but it doesn't change the rear suspension. It's still gonna be bouncy on rough roads. Upgrading the hitch is never a bad idea but doing it only to remove the WD hitch may be...
/ New receiver to avoid WDH setup? #35
I bought an adjustable ball mount and I feel it was money well spent. It gives you flexibility in case you don't know how a trailer will ride best on your truck with whatever load you happen to be putting on it.
I have a Curt adjustable with all three ball sizes and a straight (no drop/rise) one also with all three balls. I wouldn't pick something up far from home without bringing both of these with me just in case. I've got on the highway before, drove a couple miles, and then decided to stop and adjust. It's better than white-knuckling for dozens of miles!
Many trucks these days have specific trailer weight (and tongue weight) ratings for conventional / bumper pull, gooseneck, and fifth-wheel. The BP rating is probably limited by the rear suspension or the frame. So if your truck specs / manual say BP is max 10K, no matter what receiver you put on, you should not exceed 10K, even if that truck is rated 22K fifth-wheel.
/ New receiver to avoid WDH setup? #36
RE the tow ratings, try to find that printed on the truck anywhere. You're find max front and rear axle weights. You're find your registration weight. You'll find a tag as to the hitch rating.
At least around here when you scale, either full on or the portables, you can't exceed the total weight and you can't exceed your axle weights. They sometimes check hitch equipment and brakes, but they certainly don't start phoning around to dealers with your VIN trying to see if you have the right engine options and tranny cooler to get the higher tow rating.
/ New receiver to avoid WDH setup? #37
So I haul RV trailers and my PJ 10k rated equipment trailer but not at the same time. In the past the ball height was very similar for both of these trailers and I used the same WDH setup on them. I replaced the RV with a modern one which is much much taller. The ball height is way at the top of the grave digger drop shank. This is unacceptable for my equipment trailer and I am now looking at buying a seperate WDH setup for 300$ for the equipment trailer. I will NOT be raising and lowering the ball height on my current WDH setup each time I want to tow.
Even on a big honking diesel F350 the factory receiver is not rated to tow the equipment trailer without a WDH system. I believe the weight carrying hitch max was only 500# tongue weight.
So I discovered that it is actually cheaper to replace the Ford receiver with a class 4 or 5 receiver rated for a 1000 lb tongue and 10,000 lb trailer without a WDH and then buy a hitch and ball that can also be found rated for 10,000#. This will mean that my receiver is more substantial for RV duties, and also it will be easier to hitch up the equipment trailer.
What is the boards opinion on upgrading the factory receiver instead of buying a second WDH setup?
Something ODD about that picture.
To need the ball that high on that shank kinda suggests to me that the truck SQUATS a LOT - - either because it is weak and wimpy in the rear springs, or because you load it.
Is that your "big honking diesel" ?
If so - they're not, at least the SRW ones aren't.
Anyway, if truck squat is your REAL problem the solution may be to get your Springs repaired, or add air springs, which soften the ride considerably even when running empty.
They also help compensate for loaded/not-loaded headlight aim.
/ New receiver to avoid WDH setup? #38
A lot of trailers are just high. I have to use a 6" rise with my F350 4x4 on my deckover bumper pull.
New trailers, especially this one, are tall. The trailer is sitting in my shop all leveled and if I walk into the ball mount it will hit me in the groin. They are really really tall. Getting out of the trailer takes a three step folding staircase and then a fourth full step before you hit the ground. This is a brand new 2012 Outdoor RV trailer made in Oregon by the same company that makes Artic Fox trailers and Nash. My last trailer was a nash and was much lower. Overall height is still under 12' but ground clearance is excellent.
The F350 has been lowered to F250 height by changing the blocks under the leaf springs. All springs and overloads are still F350 OEM. This dropped the hitch just over 2". The trailer's full tongue weight drops the rear bumper 3" and then when I set the WDH the bumper regains one of those inches for a total drop of 2" and just barely touching the overloads. It actually rides very nicely and level as set up. That crazy shank was 100$!
So the problem, Reg, is that the trailer ball mount is tall. Truck is fine. Trailer has max GVWR of 8200 so we're not talking a huge trailer. In fact, many folks report towing this size of trailer with half ton trucks.
Perhaps a picture will help.
WOODS TBW144 TURF BATWING ROTARY MOWER (A62130)
WOODS TBW144 TURF...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
New/Unused Landhonor 72in Quick Attach Rock Bucket (A61166)
New/Unused...
Butler MFG Water Tanker (A63118)
Butler MFG Water...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61569)
2014 Crossroads RV...
Case skid steer wheels and tires (A63118)
Case skid steer...
