BX Hood Latch Surprise
/ BX Hood Latch Surprise #1
CHDinCT
Conn. & Florida
Kubota BX25, Z422-KW
Did you know that your BX hood latch has a plastic latch hook that you're suppose to use to hold the hood slightly open while you slide the plastic engine cowl out? I didn't either until I read the little sticker by the muffler outlining the procedure for removing the engine cowl. Hadn't noticed that sticker either. Anyway, came across this doing my 200 hour maintenance today. Don't recall it every being mentioned so thought I'd highlight it for anyone unaware it existed.
Photo's are kind of lousy being cell phone pic's, but that's all I had available when I saw it. I've had a BX for close to 4 years now and just never tripped across this little hood latch hook.
[/IMG]
[/IMG]
/ BX Hood Latch Surprise #2
Only for you steel hoodies, not us plastic ones. :(
Why not? I don't see the difference as far as plastic or steel goes. You still have to open the hood slightly to slide the cowl out, no?
/ BX Hood Latch Surprise #4
Yep, I use mine when removing the cowling.
/ BX Hood Latch Surprise #5
It's in the manual of my BX2660 too. Works well.
/ BX Hood Latch Surprise #6
Because my plastic hood is so light that it stays up on it's own. :cool:
/ BX Hood Latch Surprise #8
I always thought it was to let some of the excess HP bleed out when needed. :cool:
/ BX Hood Latch Surprise #9
I couldn't find the strap on my BX25 until I went to remove the battery for winter storage. There is was.
/ BX Hood Latch Surprise #10
Found it years ago. And yes, plastic hoods have them too!:thumbsup:
/ BX Hood Latch Surprise #12
What is the cowl? Why is it being removed? Obviously I didn't know about this feature since I didn't know I had a reason for utilizing it.
/ BX Hood Latch Surprise #13
When you want to remove the wrap around front cover (bonnet side by parts manual) for the engine, the front of the hood (bonnet) will obstruct it when you loosen the knobs and slide it forward. With the hood held in that position, the piece slides off easy.
Deano
/ BX Hood Latch Surprise #14
Deano
Thanks. Now I know what people are referring to when they write about the cowl.:D
/ BX Hood Latch Surprise #15
Thanks for the tip. Just did my 300 hr service today and that would have really helped.
/ BX Hood Latch Surprise #16
I have just always removed the four nuts and the plastic hood on my BX24. Just seemed logical to have it out of the way if I had to pull front grill bar & cowl.:confused2:
/ BX Hood Latch Surprise #17
I can't find mine either. Guess I'll look behind the battery. Went to do my 100 hr. service today, (the first nice day since last year) and no hood strap.
/ BX Hood Latch Surprise #18
I hear ya on the nice day, McCash. I got a plugged underground drain pipe. I'll be firing up the BX-25 shortly to see what the problem is. When you own a BX-25, digging becomes fun.
/ BX Hood Latch Surprise #19
They are kind of hard to see.
/ BX Hood Latch Surprise #20
Now you tell me?? ;) Thanks for sharing. I may have to go out to the tractor right now to see if mine is there! I've had mine 8 years maybe(?), and didn't know about that.
EDIT - I'm back...yep, it's there! Thanks, and thanks to TripleR for the pics. Wouldn't have found it otherwise.
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
PT Anhydhous Tank (A64127)
PT Anhydhous Tank...
Landhonor Quick Attach Power Rake (A66408)
Landhonor Quick...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2019 GMC Terrain, AWD (A62679)
2019 GMC Terrain...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
