501 sickle mower tech ?
   / 501 sickle mower tech ? #1
Edelpils
Leroy, Texas
Ford 515
I have a 501 sickle mower. Already used it this year to cut three acres of coastal hay. Sometime during the process i broke one of the blades. Never fixed one so started to read the forums. I was able to figure out how to get blade out. Pretty easy. Ground down the rivets and was able to get the old rivets out and remove blade. Here's the tech Question. The new blades that i bought from TSC are slightly higher than the old blade. The old Blade is 2mm high. The new blade is 3mm high. I know this is not going to effect the cutting side because the base will be equal. What i would like to know is on the top side the knife clips holding it down are sliding on this blade and two others that are smaller. So the question is will this effect the balde sliding back in forth or will the knife clip somehow get over that 1mm differance. As of right now, i think to fix it would be to change the 3 blades that the knife clips slide on. What do you guys think?
   / 501 sickle mower tech ? #2
I think a picture would really help me undestand better ... it sounds like you may have the wrong replacement parts? Or maybe the older parts are worn down where the new ones aren't?
   / 501 sickle mower tech ? #3
The TSC knives may be heavy duty which are slightly thicker. Put some shims under that knife hold down clip so that it slides easy under it.
Bob
   / 501 sickle mower tech ? #4
Things will kinda wear themselves in to work out, but it's a little less than perfect to mismatch sizes like that. Probably replacing the 3 and shimming the guard (thin metal with 2 holes to match) would be the right way.
-->Paul
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2000 Dnya RGN (A49461)
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
