Interesting dump mechanism
/ Interesting dump mechanism #1
bcp
Super Star Member
SW WA
Kubota BX2360
I've been looking at the methods used for dump trucks before hydraulics were common. I usually see gear drives or cable and post. This is a new one for me.
This is a large photo so you can zoom in.
GMC Heritage Editions Unveiled | Pro Pickup
1912 GMC
/ Interesting dump mechanism #2
That is intriguing! I looked at it quite a while and still don't know if I fully understand it all. It appears that those lift arms where the chains are connected would almost touch the ground by the front wheels when the box is down because those angle iron drops that are riveted to the frame behind the front wheels would prevent the arms from moving parallel to the frame. Or does the connection to the box at the bed have rollers that roll back when the arms hit the angle iron drops?The box pivots down low on the wheel axle and it appears that it has to get started lowering with the chain pulling it down until gravity takes over. Thanks for posting!
Donman
There must be just enough clearance to get by. That's the only place for them to go.
I think the angle iron keeps the lift arms away from the spring shackles. etc.
Bruce
/ Interesting dump mechanism #5
The billboard in the rear, says "Les Miserables" yes? Interesting.
That truck is a beaut!
/ Interesting dump mechanism #6
I think the arm attached to the bed is hinged and fixed there. The chain pulls on the opposite end of the arm, effectively shortening the base of a triangle, tilting the bed up, kind of like pushing an open, face-down book's edges together would raise the spine. It looks as if the arm is carried on the roller to reduce friction and carries the beam as it rides back and forth. As the chain shortens, the frame member pushes the bed up, and carries the slack chain with it.
Cool find, thanks for the picture!
/ Interesting dump mechanism #7
Wasn't there an army utility trailer with a dump like that? Flip a lever and back up and the bed lifted up as you reversed (or pulled forward would make better sense)? I'm sure I've seen something military that did that.
Bye for now,
Troy
/ Interesting dump mechanism #8
Donman
The arms are on a fixed pivot on the bed and guided by the rollers on the bed. As the bed comes down, the arm tips will arc forward and up, probably finishing parallel with the frame.
I love old machinery. It intrigues me what was done before the days of welding, hydraulics, lightweight alloys and everything else we take for granted.
/ Interesting dump mechanism #9
It is the same thing when you get a regular dump with a frozen load and wont come down, put a chain from the bed down and under the rear wheel and pull forward pulling the beed down till load gets back over center.
tom
/ Interesting dump mechanism #10
In place of the chain drive what if you mounted a winch at the rear of the truck frame ans used it for controlled up/down? If on a trailer you could mount the winch up front and run the cable to the back through a snatch block then back toward the front to grab the arms. If you did it this way the winch would be available for dragging things into the trailer bed by rerouting the cable as needed. I think you can get wireless remotes for winches and that solves the control link problems.
/ Interesting dump mechanism #11
That would work, but you would either need to run a pair of winches, or go to a single, center mounted lift arm.
if the winch were mounted at the front, going around a pulley to the lift arm would double the compression force seen by the bed or truck frame. I think swapping the cable(s) each time would be annoying. Winches dedicated to either or loading exclusively would make more sense to me.
/ Interesting dump mechanism #12
After looking a bit, I found an old advertisement that shows the bed party lowered. It is about 3/4 of the way down here, along with some other neat pictures of the Reliance/GMC trucks of the period.
http://www.shiawasseehistory.com/gmc.html
That looks more like the winch idea. Instead of a chain, it seems to be a strap that winds up on the powered drum.
Bruce
/ Interesting dump mechanism #14
Wow! Impressive.
Look at the tires. Can you image what a dump truck on those tires with the roads of that era rode like? Maybe that is where the "rides like a truck" expression came from:D
Thanks for sharing!
Ken
30 Yard Dumper (A61166)
30 Yard Dumper...
2500 GALLON INDUSTRIAL TANK (A62130)
2500 GALLON...
UNUSED ATS DJ2200 ELE. LIFTING MOTOR (A62131)
UNUSED ATS DJ2200...
Front and Rear Studded Tires (A63116)
Front and Rear...
2015CATERPILLAR 329FL EXCAVATOR (A62129)
2015CATERPILLAR...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
