DK 45 50 hour service
/ DK 45 50 hour service #61
Nobody said the oil needed changed every 50 hours.
They said its the first 50 hours then every 400 .
I know vince but why not every 50 hours???? More the better right???
/ DK 45 50 hour service #62
My owners manual says change the hydraulic oil at the first 50 hours, then every 300 hours after that.
Do I think the oil needs changed that often ? NO I do not.
I changed my hydraulic oil the first time at 100 hours for 1 reason only. Warrenty.
I didn't want to risk my warrenty if I had a problem.
My second hydraulic oil change I went 600 hours and the oil still looked like new.
My last hydraulic oil change I ran it 800 hours and when I changed it the oil still looked like new, so I plan to run this new oil 1000 hours before I change it again.
I do change the hydraulic filter every few hundred hours.
My front axle oil gets changed on the same schedule as the hydraulic oil.
/ DK 45 50 hour service #63
My service manual says no hydra oil change till 400 hours.
/ DK 45 50 hour service #64
For what its worth my Service book does not have that dot and I am done with this. You want to change your fluid every 50 hours/ Have at it, not me. If you guy's lived closer I would have liked to pickup your overused oil....
what amazes me is you stated earlier that you prefilter your hydraulic oil....that worrys you. but you steadfastly refuse to believe that a 50 hour change would be a good thing to do. if nothing more than added protection of an expensive piece of equipment
/ DK 45 50 hour service #65
I don't find it so hard to understand. At 50hrs the oil is hardly likely to have lost critical performance characteristics and most manufacturers don't seem to recommend such an early change. Does anyone think automatic transmission fluid in a car needs to be changed after 3000 miles? If the fluid has wear particles from break in then either the filters take those out efficiently or your HST oil should be changed a lot sooner than 50 hours. Why tolerate debris from manufacture or initial wear for 50 hours unless it is reliably filtered? On top of that, there is always the risk of a screw up or contamination when changing fluids.
I replaced mine per maintenance schedule shortly after 50hr but it felt really dumb.
/ DK 45 50 hour service #66
I said my work filters there oil!!!!! Quit being a lawyer. And go change your oil!!!:laughing:
/ DK 45 50 hour service #67
See 1-17, in the SERVICE book NOT the owners book. No warranty problem.I am sooo done with you...Go spend your money fool.
Fool?? Amazing, try to help someone and you get called names. Like I said have a nice day. CJ
/ DK 45 50 hour service #69
If it did not effect what Kioti specs for warrany then I would not be dumping the oil either. If I could check all the drain plugs and magnets for metal it would not bother me to do that and just change the filters. But if asked what is it worth to be 100% honest. CJ
/ DK 45 50 hour service #70
I agree. It is disappointing when companies take a CYA approach and force the customer to bear unnecessary expense as well as waste perfectly good and expensive natural resources. You'd think that in this era of mucho expensive oil products that engineers would incorporate simple ways of cleaning out metal filings and making filter changes without loss of much oil. It is particularly galling as HST pump and transmission failures seem to be almost rare as hen's teeth with modern CUTs. I appreciate that when we attach hydraulic implements we break into the system but that is what filters are for and it certainly doesn't degrade the lubrication or other qualities of the oil. I really wonder if there is greater risk in fiddling with the oil change than there is in just leaving the system alone or just changing the filter. I also wonder what is so different about automobile ATs that allows Mercedes and others to essentially load them with ATF at the factory and seal them so that nothing needs to be touched or even checked (there is no transmission dipstick anymore) for 100,000 miles (2000hrs or so)? Aren't ATs and HST systems kissing cousins in terms of wear and protection?
/ DK 45 50 hour service #71
You must have a different Service book than mine cause my book says filters only.:confused2:
/ DK 45 50 hour service #72
If you need any info from the service manual let me know. CJ
Thanks, CJ,, will keep that in mind, I asked in an email to have the dealer price me out a set, I guess I will see how bad it is going to be, but I think it is something I should have. I am not a very good mechanic, but sometimes with a good manual you can thread your way through things.:)
James K0UA
/ DK 45 50 hour service #73
James K0UA
No problem, should be $75. You can also download them but I did not have good success doing so. Like has been stated you will get conflicting info in the manuals so double check things. My manual says 225ft lbs for the front tires!! should be 150ft lbs. CJ
/ DK 45 50 hour service #74
Wow 225ft lbs.. hum I wonder what is going to break first the bolts or the cheater bar:)
James K0UA
/ DK 45 50 hour service #75
Yes, in fact a couple of manufacturers spec dextron 2 as a fluid for their hydrostatic systems. Dennision being one of them. I would bet that at least 1/2 of the hydrostatic system failures are a result of improper repair [dirt in lines, no charge pressure ect.] With 1 of my big hydrostatic customers they have only 3 employees that are allowed to touch anything to do with the hydrostatic systems. Our tractors are filtered so well that the dirt would have to pass through 2 filters to get to the stat, so dirt from couplers should be a non issue. After this initial 50 hour thing I will do oil sampling on mine just to find out how clean the systems stay. I actually stock a Hydralic oil that is rated for 12,000 hours, so I can't believe this oil in the tractors will not run longer. The sampling will tell the story. CJ
/ DK 45 50 hour service #76
James K0UA
I am a little red faced with this one:p. I have torque wrenches that go to 600ft lbs. When I got to about 200lbs something told me this was not right. so I started looking elsewhere and found the 150lb spec. I didn't tear anything up! CJ
/ DK 45 50 hour service #77
All the references to warranty in this post got me curious enough to read the Kioti warranty on line.
Kioti Tractor Warranty
Aug 1, 2010
C. The General and Extended Warranties do not cover the following:
Section C Item 2 A repair made or parts replaced or modified by anyone other than an authorized KIOTI dealer.
D. The warranty for any tractor immediately terminates if any of the following occur:
Section D Item 2 Any replacement parts used on the tractor are other than genuine KIOTI brand parts;
Item 3 Any repair made or parts replaced or modified by anyone other than an authorized KIOTI dealer;
Section H No modification of Warranty
This warranty is the only warranty authorized by KIOTI Tractor for tractors and attachments. Neither the KIOTI authorized distributors, dealers, nor any other party has any authority to make representations on behalf of KIOTI Tractor to modify the terms and limitations of this warranty.
Even if you use Kioti parts and follow the instruction of the dealer you can't replace them without voiding the warranty. Filters are replacement parts. WIX or what ever your preferred brand oil filter are not Kioti parts.
Even if your dealer tells you that any brand Hydraulic oil will do, if it is not in the book as "Kioti" recommended you have likely voided the warranty.
Just my thoughts. Gonna go relax and enjoy using my tractor.:licking:
/ DK 45 50 hour service #78
My dealer gave me a bag of filters and some grease upon signing for the tractor, You reckon he thinks I am going to do that 50 hour myself..:D:D
James K0UA
/ DK 45 50 hour service #79
I have two owner's manuals for my 2006 DK45S and they show different maintenance schedules. An older user manual I got from my dealer (it was the one he kept for his shop) showed major items like change hydro fluid and front axle oil at 300 hours. The newer user manual (and also the shop manual) show these same jobs at 400 hours. What's annoying is that there are no dates, version numbers, etc. to identify the different editions of these manuals.
I think the shop and users manuals for the newer models are much better than the manuals for my tractor. I base this in my read of the different manuals on the Australian site (their DK451 appears to be the same as my DK45S). By better, I mean better explanations of the systems and more complete, for example, my manuals (both owners and shop) fail to mention several of the zerk fittings that need grease.
/ DK 45 50 hour service #80
My owners book says filters only but the graf chart shows a dot on change transmission fluid.
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 Ford Box Truck (A62613)
2017 Ford Box...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
