my new YM2210!
/ my new YM2210!
I agree on the shift boots. They would look much better black.
I was out yesterday working on getting it dirty. One funny thing, while I was working, I heard this loud intermittent noise. I was listening to music, but finally realized the tractor was making it off and on. I was a little scared something bad happened. I got off and looked it over and finally convinced myself that the horn was sounding randomly. Fredricks doesn't connect the horn, but it's still there and the wires go who knows where. Apparently the hot wire was occasionally touching something hot. BEEEP! :D
Another funny observation. I have unfortunately discovered that the YM2210 is so much more powerful than the YM1700 that I can leave the parking brake set and still go... and not notice until I stop and go to set the parking brake again. *arg*
/ my new YM2210!
Are the rear wheels the same bolt pattern as your 1700? The fronts are the same at Hoye, but I couldn't find anything for the rear.
284 -- not sure I understand what you want to know. I believe the current YM2210 wheels do match the YM1700 bolt pattern, but I'd have to double check to make sure. What are you thinking about?
/ my new YM2210! #23
Clemson, have you looked into filling the tires with foam? I've used Slime before, with good luck, on motorcycles, but if you're getting regular punctures, maybe foaming them would be worth it.
I thought about it last year, and asked the local guy that lives near me, who i take tires to local to my house. He said that there is a person in the next town that foams tires. At my farm im only there on the weekend and really on ly have 1.5 days when there so not much time to do things like this. If the cost is not to great i think i will probly get the fronts foam filled. As far as the slime it would have to go into the tubes. This last puncture i got was a peice of stick between 1/4 and 1/8 think that punctured, does slime fix that?
/ my new YM2210! #24
You just put 5 years of wear on that brake!!
/ my new YM2210! #25
For the same reason some of the hoses are painted etc, its way easier to just spray them too than to mask it off. This i have noticed is common on tractor paint jobs.
my boot never got painted, the return bit of hose did but not the boot?
/ my new YM2210! #26
Nice 2210! I am envious of you, I sold my Yanmar in January and miss having it around. I do have the skid steer taking its place but that little YM169D was a great little tractor for light work. :eek: Now that i have said all this, I can see myself getting another Yanmar down the road some day. :thumbsup:;)
/ my new YM2210! #27
I was mostly just curious if the rims are the same or not. I remembered you pondering about whether to keep or get rid of a spare set of turf tires for your 1700 and was wondering if those would work.
/ my new YM2210!
dont worry, it will crack and peel pretty quickly once you start to use it. paint on rubber dont go very well :D
I was thinking the same thing, and I was thinking about encouraging it a bit. :thumbsup:
/ my new YM2210!
Good memory on the spare tires on the 1700, although the spare set was the rice tires. I'm advertising the 1700 with the turf tires on.
/ my new YM2210! #32
Doh! :eek: And I'm NOT going to admit that I did it twice... :D
Good thing they last for like 50 years! If a guy dont ride around with the brake on all the time. I would not worry, i have done it for like 5 mins before. You may find in 5 years you need to turn them over but thats all? My right side creaks more then my left and also will lock up faster, i need to pull the covers check all out and if good adjust them to even tension.
Unused HLA HD42 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused HLA HD42...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
2007 Toyota Rav4 SUV (A66738)
2007 Toyota Rav4...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A66736)
2016 Peterbilt 579...
2009 FORD E150 CARGO VAN (A66091)
2009 FORD E150...
