JD 400 Backhoe pulsating weak hydraulics
/ JD 400 Backhoe pulsating weak hydraulics #1
JimmyBOD
centennial, co
JD 400 Industrial Backhoe
I have a JD 400 built in 1966 and it has run fine until lately. The JD dealer has cleaned the sludge screen filter and installed all new filters in the hydraulic lines. The dealer thought the machine was running correctly when I picked it up but when I tried the hoe and the bucket the pulsating hydraulics along with weak power was still prevalent. The transmission, power reverse, power steering and brakes all work fine. The JD dealer wants me to take apart the Pressure Control Valve and look for problems. I see the trans, a box next to it that is probably the reverse box and next to that a housing for the brakes. Can't find the pressure control valve on this unit that matches the pictures from the manual.
When the tractor is running, the tank above the pump, AR101807, has fluid in it. The dealer did not take any pressure or flow measurements in the pump when it was in the shop. It has been 10 years since the pump was rebuilt. Any clues of what to do next to remedy the pulsation and get the power back?
/ JD 400 Backhoe pulsating weak hydraulics #2
there could still be some sludge lurking around in your pressure controls,pending on how bad things were you may have picked up more in your screen. on your pump you have a destroking valve in the end cap of the pump that can get clogged causing chatter. you should have a relief valve in your control valve near the inlet. these parts are sensitive and close attention needs to be paid when inspecting them. I don't know for sure if your model has one but jd used to use an auxillary pump also it may be cavitating as well.
Thanks for the tips. When the tractor was at its worst, the JD tractor mechanics worked at cleaning filters and the sludge screen. They filtered the old oil and put it back the tractor. I removed all the oil and rescreened it. I did find some dirt/sludge in the oil they put back in. (?) I still can't find relief valves. The tractor mechanic asked me if the loader had a single joystick. it does. I dont know why he needed to know that.
/ JD 400 Backhoe pulsating weak hydraulics #4
Your joystick valve probably has a relief valve close to the IN port.
Can you show a picture of the joystick valve especially the top of the valve.
J_J:
I have attached a jpeg of the view I think you asked for. If not, I have more of the hydraulic lines and parts. The hoses on the left are the in and out (?) and the other goe to the cylynders. I guess. JimmyBOD
/ JD 400 Backhoe pulsating weak hydraulics #6
Sounds like the pump. If its what I think it is its an Oil Gear pump. THey are a radial piston pump and has pugs and pistons around the outside of the pump. We had this happen at work on one of the JD scrapers. One pump had a worn piston and had good presure till that cylinder and one had an egg shaped bore. Kintec remans these pumps.
Thanks Taylortractonut:
It does have a spline pump, AR101807. I have talked to Jerry at Kintech about his pumps. What worries me about him is I googled his address and it showed up as a road in a forest in Missouri with no building in sight. A&I sells the same reman about $300 more.
I have about half of the tractor mechanics focusing on control valves and dirty fluid and filters, and a few focusing in the main pump. Some maintain it is the pump in the trans but the tractor moves, steers and reverses and has brakes.
J.J:
Thanks for the picture of a relief valve. Tommorow I'll get out and under looking for a valve and taking pictures. My manual is for a 2040. The pressure control valve in the 2040 manual does not exist on my tractor.
If I find something that might be a relief valve, should I open it up to check for worn parts, bushings and dirt?
The hydraulics failed slowly and over a week or so there wasn't much left that didn't shake. I am assuming that comes from the main pump. It is not working correctly (worn) or is cavitating because it isn't getting enough oil. Is that it?
JimmyBOD
/ JD 400 Backhoe pulsating weak hydraulics #10
look at a 2020 they're closely related
/ JD 400 Backhoe pulsating weak hydraulics #11
The JD400--Industrial version of the 2020
Is your hyd system open center or closed center?
Tractor specs says it is closed center.
You need to know what your tractor hyd pressure should be.
Install a 3000 psi hyd gage in the IN port of the FEL valve, or at the IN port of the BH valve.
Max out each of the BH cyl and check pressure.
The pressure relief on the BH should be set the same as the FEL valve relief.
You could inspect, clean the relief valves.
/ JD 400 Backhoe pulsating weak hydraulics #12
unless you're familiar i wouldn't take it apart. i would flush it blow it out with air use a light to inspect all the holes you can see. there should be a tiny port dead in the center that balances the pressure so that the valve works smoothly, also one near the threaded end, some times pending on the valve you can run a small gauge wire through them and clean them, either one can cause your problem. with some valves it is better to just replace them. not all are easily rebuildable.if you still want to try take note of all the parts you remove and put them back the same way. remember this is the part that keeps things from blowing up. i suggest that unless you find evidence of contamination and are able to clean it. replace it it's probably time anyhow.
Honestly, JJ., I don't know. Most of the posts I've read say these tractors are closed systems. In another post I found the moderator said the Pressure Relief Valve in located under the floor plate on the the right side of the tractor. Will go look at that.
I want to thank everyone who has posted info to help me with this issue. You have given me many things to work on. Also would like to post a picture of a part that I found in the fluid when I drain the hydralic fluid from the plugs around the filter. It is a small part that might have contacted a spring of something else, don't know what. I took it to the JD dealer, head mechanic in Parke, he was too young to have worked on these tractors so he wasn't any help. Anyone know what this is and where it goes?
/ JD 400 Backhoe pulsating weak hydraulics #15
When your hydraulics start to surge, have you checked the reservoir to see if there is foaming. Air leaks into the system during high fluid demand could be sucked into the pump and give you surging much like fluid starvation. Just to be on the safe side, I'd inspect for tight fittings along the suction lines and check for foaming caused by air.
/ JD 400 Backhoe pulsating weak hydraulics #16
If your hyd system, is closed center, all valves are in parallel, and there maybe only one relief located close to the pump.
There are replacement valves that can be converted to closed center and will have a relief valve on them.
Hydraulic machinery - Wikipedia, the free encyclopedia
Skip down to the closed center area.
/ JD 400 Backhoe pulsating weak hydraulics #17
See if you can work the tractor for half a day. we just blew an o ring at transmission case connection. Ours was slow and iwork at first. after it work for wall the fluid was low. after we got it full it was okay. running seafoam in it at this time.
That is the funny thing about the way the tractor acted. First the main pump leaked around the spline shaft. The JD dealer wanted to put a reman pump at the get-go. Then he decided he would try to just install the seal. It worked. No leaks. I used the tractor for about 4 days and it seldom pulsated.
When the tractor started pulsating alot I had the JD dealer work on it. They cleaned out the screen filter and replaced the filters and the tractor did not pulsate.
When I tried to dig with the hoe at a job site, it pulsated a great deal and had no power. I doubt the JD dealer checked to see if it had power. I know he never put gauges on it to see what the main pump was all about. The dealer is thinking the pressure control valve is the problem. But they work on green tractors that are new and don't know much about old yellow iron. The pictures they gave me about the pressure control valve don't resemble what I find on this tractor.
/ JD 400 Backhoe pulsating weak hydraulics #19
that part looks like some sort of poppet possibly from a valve should be a spring somewhere in there also
The tank above the main pump is full of fluid. When I open the nut on top of the tank, there are three hoses that connect into the bottom of this cap, fluid flows out. So the tank must be under pressure and full of fluid. One of the hoses go back to the bottom of the main spline pump. One goes to a housing that sits behind the fan above the crank pulley. I think this housing has something to do with the power steering and the reverser. One line, rubber hose, goes to the top of the shift box. I'll check these for leaks. Thanks
