Rear Wheel Weights?
/ Rear Wheel Weights? #1
duwem
John Deere Garden Tractors
What are you guys using? Original ones offered with the tractors, or something else you made fit? Need some weight on my rear wheels on my Beaver.
/ Rear Wheel Weights? #2
I have used all combinations of things, and made some non-original weights work on my tractors. Liquid is the easiest and cheapest. Have you considered doing that?
Tire place estimated 22 gallons each tire, times $2.75 a gallon. So around $120. Does that sound right for the gallons? These are 9.5 x 16 Firestone R1 Tires.
They said if my intertubes have a small valve stem they would want to change them to big ones, and thats expensive.
Could pull the tubes out and run just the tires, but not sure if that would seal.
/ Rear Wheel Weights? #4
I used windshield washer @ 1.50/gal in non-tubed 8-16s and could only get about 8 gallons in each. I'd be surprised if anybody could get anywhere near 22 gallons in a 9.5-16 but I've been surprised before...
Ya, they have some chart they look up, he was not sure which one on the chart to use. 22 gallons seems quite high to me as well.
/ Rear Wheel Weights? #6
Maybe they meant 22 gallons total? This chart says 12 gallons per tire for the 9.5-16, and seems more reasonable.
/ Rear Wheel Weights? #7
I made my own wheel weights from old cast iron olympic weights. The older 33lb olympic weights fit the diameter of our wheels perfect. so I took one of those, and one 50 lb non olympic and welded them together. (83 lbs per wheel) I drilled them for the bolt pattern but have not installed them yet. I made them for my turf tires and ended up trading them for filled ags. I was amazed at the difference the filled ags did compared to the unfilled turfs. Before it was just spin, diff lock on in 4x4... now it just bites and goes, unless I'm taking a huge bite with the box blade. I'm still going to install the weights when I get the loader functional.
I would think it should pull it just fine. our machines are very light in the front. For my box blade, I used 175lbs up front and that seems to work, and it could still take a little more. I think you'll be surprised how well it will perform with filled rears and 150-200lbs up front. I know I was..
I made a weight bracket to hang 5 42lb suitcase weights on the front end and purchased some wheel weights designed for the rear of a John Deere 4400 combine which weight a whopping 158lb EACH.
Needed to drill a new set of holes in the rims (in a ribbed section, using a mill and 1/2" end mill, goofy spacers etc). Weights fit the depth and diameter of the rims perfectly!
/ Rear Wheel Weights? #9
Those look terrific, and the difference in performance will be impressive. Great work, and nice find.
How do you mount that assembly? Do you attach the wheel and then install the weights, or put the weights on the wheel and install that?
Wheels to tractor then weights to wheels with long 1/2 bolts.
Hope I dont bang up the paint bad or worse yet break a finger mounting them!
/ Rear Wheel Weights? #11
Get some long all thread and put a nut on each side of the wheel to hold the stud, then just a nut on the end. Would be alot easier to mount...
Weights are all painted up, will let them dry for a couple of days then mount them up.
Will post pictures of them on the tractor when I get to that point.
/ Rear Wheel Weights? #13
I just bought a cheap parts tractor. It runs! Its a kubota b6000e with a cccw pto. I bought it strictly for the ccw woods rm59 finish mower, kubota dozer blade (no springs, actual dozer blade) and a set of kubota wheel weights. Then i'll sell the tractor for more than i paid for it! Lol I just got the Kubota wheel weights off (8-16 rear tires). They will fit perfect on the outside, but the centers are open almost like they can go on the inside of the wheel. The center opening is 7 1/2" and our rear hub/flange looks to be 6 1/2" so I think I'm going to try to put them on the inside for a cleaner look and availability to put on another set down the road if needed. Idk how much they weigh yet, but they feel like 80-90lbs each. Hopefully I can get my wheels off this week to get them painted up and attempt to mount the weights on the inside (which would actually be the outside, since my wheels are flipped).
Thats kind of a neat tractor.
Wheel weights mounted up and DONE tonight.
Attached a pipe to my loader with some chain and clamps and just drove up to the wheels with the weights on the pipe. Worked out real well.
/ Rear Wheel Weights? #15
Those look great, and will really improve traction for your machine.
/ Rear Wheel Weights? #16
I found weights that were a good fit except they covered the valve stems. Adding curved valve stem extenders from an RV parts dealer solved the problem.
I posted a thread about this last year.
Saturday I'm going to attempt to pull a 16" 1 bottom plow with the the tractor.
I have 210lbs worth of suitcase weights on the front as well.
3pt Hitch Receiver (A62679)
3pt Hitch Receiver...
2025 ALCOM XPRESS XLT 24FT T/A CARGO TRAILER (A59914)
2025 ALCOM XPRESS...
20ft Driveway Gates (A65579)
20ft Driveway...
(6) 250 Gal Chemical Containers (A64127)
(6) 250 Gal...
1995 WILSON PACE SETTER DWH-400 HOPPER BOTTOM TRL (A64277)
1995 WILSON PACE...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
