Three Point Trailer Hitch Reciever
/ Three Point Trailer Hitch Reciever #22
Well I made one too, one of my first real welding projects. It's not prettied up and painted yet though.
Ken
/ Three Point Trailer Hitch Reciever #23
Harbor freight has these. ATV Hitch Adapter
I used one for a winch mount on a trailer so I could remove the winch and I can put a ball mount on it and use it to hold a wood splitter on the trailer.
/ Three Point Trailer Hitch Reciever #24
My mom bought my dad one that was made by tarter gate company from the local Co-Op with a 2 5/16" ball next to the top pin. It is light duty made from thin 3"x3" square and had a sticker on that said don't use to move a loaded trailer. You can especially tell it when moving a gooseneck. I kind of copied the design and beefed it up. The one I made is from 4"x4"x1/4" square and more bracing. It is one of the handiest attachments we have.
/ Three Point Trailer Hitch Reciever #26
A hitch system is one of the handiest tools for any tractor. This one stays on the tractor when other tools are not in use. She uses it mostly for her trailer around the place barking and brush removal. Told me my rig was too big so had to get her one her size.
This pic is of her backing to toss a set of tongs on the log. Was enough lift to get one end off the ground for removal.
Is the winch electric, or hydraulic? I'd like to see a better pic of it if you have one. :thumbsup:
/ Three Point Trailer Hitch Reciever #28
10,000 electric with a quick disconnect at the rear housing.
I have the same thing almost on the back of mine that is hyd as there is better flow in the 50hp deere. It also has a boom that takes the place of the upper link and extends out over the housing about 3ft. as it can put the tongs on the ground and when lifting take them to almost 5ft it makes for a good fairlead with a block on it or for picking logs with tongs.
/ Three Point Trailer Hitch Reciever #29
I always put ball-mounts and/or receiver hitches on all my equipment. My Cub Cadet super garden tractor only has a cat 0 3-point so I thought a 2 inch receiver would look a little oversized for it. I paid $10 for a 1.25 hitch made for a small car at a flea market, cut it to size and added pins and an upright, and it made a nice cat 0 receiver hitch.
/ Three Point Trailer Hitch Reciever #30
I use mine all the time...
/ Three Point Trailer Hitch Reciever #31
Stan,
I like your design.
So many good ideas here!
Ken
/ Three Point Trailer Hitch Reciever #32
I make these all the time for about $30, cheaper when I can get a free hitch.
I sold one and the rest I have traded for work. Last one I traded to a concrete guy to pour and finish a 15x40 slab 5" thick.
Its a fun and easy welding project if you have the equipment. I use a chop saw, welder, drill press, and angle grinder.
Chris
/ Three Point Trailer Hitch Reciever #33
Chris
NICE trade!!!!!!!!
/ Three Point Trailer Hitch Reciever #34
NICE trade!!!!!!!!
Yes, about 2 hours of my time to cut, weld, and paint it up. It was really a fair trade though on both parts because the guy was going to buy one for $300 at the farm store till I showed him mine that was heavier built with hooks and such built in.
Chris
/ Three Point Trailer Hitch Reciever #35
Chris
I'm sure the guy wouldn't be out much since that's what he does and the cement was probably "left overs" from another job, but my 22' X 26' garage floor 5" deep was about $2000 if I remember from about 6 years ago. Not a bad trade at all if you say your cost is only about $30 for a hitch!
/ Three Point Trailer Hitch Reciever #36
No, I paid for the concrete. It was 10 yards, $1000.
I just traded out the labor.
Chris
/ Three Point Trailer Hitch Reciever #37
Chris
That makes sense, otherwise there would have been a bridge somewhere missing a little concrete! Still a great deal.
/ Three Point Trailer Hitch Reciever #38
I simply picked up a hitch tube from the local trailer/welding shop, and welded it to my 5' box blade. That way, I can leave the box blade in place and still use the hitch to move trailers around the house. I don't have a pic, but it has worked very well (and is extremely handy). I've moved trailers as big as my Pace 22' enclosed car trailer, and it has held up just fine.
For me, I really have no use for a 3-pt style hitch assembly, as I leave my box blade attached to the tractor the majority of the time. It would be a pain to have to drop the box blade, hook up the 3-pt hitch, just to move a trailer around (especially when I can use the box blade with the hitch). However, I must admit that StanR's design is impressive, and I may weld one up just for the heck of it.
/ Three Point Trailer Hitch Reciever #39
Thanks for posting all the great ideas.
/ Three Point Trailer Hitch Reciever #40
StanR, similar to mine that I made for my 1980 Kubota B7100. Used it to skid out 5 cord of Maple firewood this Feb. I run my chain through a loop on the lower hitch & up to the top link attach point. That way you are pulling from lower down & lifting from the upper attachment point. I didn't invent it, saw it on one of these tractor forums somewhere .....
Forks and Frame Mini Skid Steer Attachment (A61572)
Forks and Frame...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2008 Ford Mustang Convertible Coupe (A61574)
2008 Ford Mustang...
