Hydraulic problem on 4720
/ Hydraulic problem on 4720 #1
rdp58
Morristown Tn
JD 3320 and JD 4720
I have a 4720 that I bought used and don't know much history on. It is a 2006 and has 650 hours on it. The hydrostatic drive has some vibration in it. The more you push the pedals down the worse it gets. C range is worse than A range. The loader works good. The PTO works but when bush hogging in tall thick grass it will stop the PTO. The power steering works good but if I have a heavy load on the front loader the steering stops working.
I have replaced the filter and changed the hydraulic fluid, wasn't that dirty, and this has not helped. I am thinking the pump is not pumping 100%. Has anyone got any ideas? I have read the service manual and do not have a flow meter to check the pump. Do I buy a pump and put it on myself or take it to a dealer and let them check the pump?
Thanks for your help.
/ Hydraulic problem on 4720 #2
Welcome to TBN, rdp58. Per the owner's manual; the transmission fluid and both filters - sump and charge filters were scheduled to be cleaned and replaced at 400 hours; IIRC.
Did you check the sump filter when you changed the hyd fluid? Your description of the tractor's symptoms makes me wonder if the sump filter has ever been cleaned. Too bad, you've got pretty new fluid in the tractor, now.
If you've got some clean buckets - you can reuse the hyd fluid.
AKfish
Yes I cleaned the sump filter. I also cleaned the smaller inline filter screens too. The sump screen was not dirty at all.
Thanks
/ Hydraulic problem on 4720 #4
Thanks
Ok, that's one possibility eliminated.
The hydrostatic drive pump is separate from the hydraulic pump(s). Vibration or noise in one does not necessarily mean that there's a problem with the other.
Stalling the pto in heavy, thick grass while mowing is not necessarily a problem... I've done that a number of times - even to the extent of stalling the tractor engine! That could just be the "packin' it in faster 'en it can eat it" syndrome! :eek: I really try to avoid that - but, sometimes there's a big 'ol clump that just gets bye ya.
And... having the power steering bog down with a bucket full of sand or gravel isn't something that is necessarily a problem, either. My JD110TLB steering will not respond as quickly or as nimbly with a heavy load as it does unloaded, either! That's not to say; that the power steering flat-out quits; but, it sure don't spin on a dime, either! And it will squawk, too... when under a heavy load in the front bucket.
That said; when the tractor hydaulics are under heavy use; but within the normal operating range for the machine - does the hydraulic system go into "relief"? The relief valve shunts hydraulic fluid back into the sump when the hydraulic pressure exceeds the valve's pre-set limit.
If that's the case, you might have a bad relief valve.
And, that's something you'll need a pressure gauge to check.
AKfish
Thanks AKfish for your response.
The hydraulic system never goes into "relief". I also have a 3320 and have bush hogged the same place with a 5 foot hog and no problem. I was using the same 5ft cutter on the 4720 and would slow down to a crawl and it still stopped the PTO. So I don't think I was overworking the PTO. The tractor engine does not drop RPM when the PTO stops. I know something is wrong with the PTO but don't know what.
I have read up on the hydrostatic drive pump today. Does it get the hydraulic fluid from the pump mounted on the engine? I really dont understand what the drive pump does.
I called the JD dealer and gave them the serial number. They told me that at 60 hours JD changed the clutch and friction plates out under warranty. The clutch might be wore out now but I think something is wrong to wear out in 600 hours.
/ Hydraulic problem on 4720 #6
If thick grass can STOP the pto from spinning, something is definitely wrong. The engine may stall, but the pto should never stop without stalling the engine.
/ Hydraulic problem on 4720 #7
OK, engine doesn't bog down - but pto stops... the clutch is slipping! I agree - the pto shouldn't be worn out @ 600 hours.
The hydrostatic drive pump is a closed loop system - for the most part isolated from the other hydraulic systems (loader, pto and 3pt) on the tractor. The hydrostatic drive pump does get some "makeup" hydraulic oil from the return oil from the steering valve after it circulates through the oil cooler and then through the charge filter.
But, it's generally not a large amount of hydraulic oil as the only way the hydrostatic motor loses oil is from the high pressure "relief" bypass valve when the tractor stalls or lugs down under a heavy load and some leakeage in the case.
That said, how exactly would you describe the eHydro "vibration"?
AKfish
The vibration is like your starting out in third gear in a four speed truck. It will go away when the speed catches up with the forward and reverse pedal position. When I push the forward pedal down it vibrates but the engine rpm does not go down. That's why I was thinking the hydraulic pump. The pump is not putting any load on the engine.
When the problem started I thought like you guys, that the screen or filter was blocked. That's why I changed the hydraulic fluid. After reading the repair manual and thinking on it, I think it is the pump. Everything that used hydraulics is not working right when there is a demand.
Can this pump be rebuilt or do I have to buy a new one?
/ Hydraulic problem on 4720 #9
There several hydraulic test ports on the machine. I would do that before you throw more money at it. If you put a long hose on your test gauge you can watch the psi when the symptoms arise. The service manual has the info on pressures and ports. You probably need some adapters, that I found was easier to order from JD, than get your hoses and pressure gauge from a local hydraulic supplier. Need a 10,000psi gauge for the hydro high pressure tests.
That being said, I don't think that the pump would cause all those issues. I would suspect a mechanical failure, like a bad bearing, in your hydro output causing the vibration and the PTO clutch to wear. I'm not very familiar with that exact model, but there usually a gearbox that controls your 3 speeds and the PTO.
/ Hydraulic problem on 4720 #10
I've always been a real beliver in buying the Technical Repair manual or CD for whatever tractor model I've owned.
Just a good, basic reference tool for many of the most detailed repairs (because most of us don't have the shop equipment to split a tractor and specialized tools and computer diagnostic equipment) - but, nonetheless it's a vital tool!!
Based on your description of the symptoms - I have to wonder about the forward or reverse potentiometer's or the proportional pressure reducing valves (forward and reverse). If you quickly push either pedal down (especially in B or C range) the engine should dramatically pull down - belch black smoke - and possibly stall... if you get real aggressive with the pedal!
You can test both the electical (potentiometer's) and the hydraulic (proportional pressure reducing valves) with a voltmeter and a hyd gauge.
But.... the pto problems are most likely "out of your league" with attempting to deal with the issue and the hydrostatic drive pump is not something that you'll likely be able to handle, either.
The best you can likely hope for is to troubleshoot, test and come up with a repair scenario - or rely upon the dealer to be "straight up" with their assessment!
AKfish
Thanks guys for your input. I have the John Deere manual on cd. I have spent several hours looking at it regarding this problem.
In the hydraulic sections under trouble shooting PTO problems: PTO slips or loses power. Front gear pump faulty or PTO valve faulty.
As AKfish mentioned if I press the forward pedal down fast the hydro vibrates and the RPM does not go down. With this problem and the PTO I'm guessing it's the faulty gear pump. if the hydro worked fine I would lean toward the PTO valve.
I'm no master mechanic but I have worked on several tractosr in the last 20 years. I'm familiar with these compact tractors and have never heard of a pump failure. That's why I am second guessing the pump. I asked the question just thinking someone else might have had this problem. I think it says something for these tractors that nobody has. Also I thought I might be overlooking something simple before spending too much money.
/ Hydraulic problem on 4720 #12
The pump on this unit is made up of two sections, the steering and the implement sections. The steering portion supplies charge pressure to the pto and the hydro.
The steering portion needs to be flow tested to determine if it is bad. What you could do is hold the steering wheel in a full turn left or right keeping pressure on the wheel and drive the unit forward or reverse and see if it affects the drive. If the tractor will not move while the steering is in relief them I would suspect the engine mounted pump is bad. If you have a gauge then you could monitor charge pressure while holding the steering in relief.
The steering portion of the engine mounted pump will effect the pto, steering and the hydro drive. The implement side will effect the rockshaft and scv.
Hope this helps
/ Hydraulic problem on 4720 #13
Hope this helps
You've outlined a very clear diagnosis... with one minor exception. The steering pump only supplies the makeup hydraulic oil to the hydrostatic drive pump @ 200psi.
If the steering pump was functioning so poorly that it was failing to provide 200psi return flow to the charge filter... I'd have to believe that ANY steering function would be extremely poor!!
Like; noticably bad steering!
AKfish
/ Hydraulic problem on 4720 #14
AKfish
The steering will have priority over the pto and hydro, it will be the last to lose function. The hydro requires the charge pressure "200psi" to function. It is supplied from the steering pump. Like I said the pump needs flow tested to determine if it is worn, but without a flow meter the least I would do is to test the charge psi per the TM.
Hope this helps
/ Hydraulic problem on 4720 #15
Did you find a solution to your Pto power loss? I have the same issue. Everything else seems to work properly, but the Pto stalls out when mowing in thick grass but the engine does not.
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2019 FREIGHTLINER CASCADIA 125 DAY CAB (A63569)
2019 FREIGHTLINER...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
2018 HINO 258A REEFER TRUCK (A63569)
2018 HINO 258A...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
