Price Check Orange Crush
/ Orange Crush #41
I am planning on loading the rear tires, so figure about 1,000 more lbs added to the weight, plus the FEL assy adds about 1,100 or 1,200.
Any opinions from members who own the L3240 and/or L3540? If you could do it again, would you again buy the one you have or go up/down?
I would put as much horsepower you can into the frame size you like the most. There are very few TBN'ers that would tell you they have bought too much horsepower, but the tractor also has to be maneuverable and fit where you want it. So maxing out the engine size on your preferred frame is the sweet spot to me. It sounds like you are financing, and the difference in the monthly payment would probably be around $35 (on a 60 month note) which seems pretty worth it to me.
Also, you will only get about 640 lbs ballast from filled rear tires on the 3240 and 3540. That is due to the tire size. Here is a link to a chart for every size for your reference:
Rim Guard Hydro-Flation Tables for Agricultural Tires | Drive Wheel Tires | Terra Tires | Light Construction Tires
Happy hunting :D
/ Orange Crush #42
How do they compare to your present tractor and will you be happy with less power?
/ Orange Crush
Happy hunting :D
Thank you for the link and advice. I am now leaning toward R4 tires, since I do most of my work on or around my yard. I am having a hard time tracking down the amount of weight that will give. Kubota spec sheet gives 420/70-24 for rear R4 size. That seems weird.
/ Orange Crush
Well my present tractor has 37 pto hp, but I don't come close to using that. I use a 5' RFM and a 6' brush hog (backward, I know). I don't really like the brush hog, it is too big. I have thought several times of trading it for a 5 footer. As far as ground engagement, I think weight (even without ballast, the 3540 weighs 500 lbs more than my L4300) and 4x4 will more than make up the difference. And as far as loader goes, the LA724 is more powerful than my LB552.
The 3540 has 28 pto hp in HST version.
/ Orange Crush #45
Then it looks like the 3540 should work well for you.
/ Orange Crush
In a way, I have been waiting for someone with a lot of tractor experience to say just that. My dad thinks I am crazy for looking at any slightly smaller tractor, but I think the overall package will be quite an upgrade in usability even though it has less engine hp.
/ Orange Crush #47
For years I ran a 6' RFM on a 1950 Ford 8N with 22-25 pto hp. Never had a hp issue. But the old Ford did not have enough power to turn a 6' bush hog. With the width of the L3540, I think you will eventually upgrade to a 6' RFM, and you still have plenty of power to do that. Philip.
/ Orange Crush #48
That is a metric tire size, and here is a link for ballast on that:
Rim Guard Metric Tire Hydro-Flation Table
A quick view of the chart shows you were right on anticipating 1000 lbs of ballast. :cool: I made the assumption you were going with the R1's, but as I am writing this I remember from a previous post that you were up in the air. Sorry to lead you astray! :ashamed:
I have to agree. It seems like you have thought through things pretty well! :thumbsup:
/ Orange Crush
Well, you were right that I was assuming 1000 lbs, but that was from checking the R1s on my current tractor, which are a good deal bigger than the tires on the 3540. I keep waffling on tires but I'm thinking R4s right now.
And thanks, I am feeling more confident about my choice all the time!
/ Orange Crush #50
More power and just a bit more power is always tempting. I picked this up from someone on here quite some time ago: "Bigger isn't always better, sometimes bigger is just bigger."
You have the advantage over many as you have already established a reference point with your present tractor on existing property and pretty much knew the right tractor before any of us.
My wife and I looked very seriously at the L3240/3540 three years or so ago and we really liked the size and maneuverability. My health and the size of our properties and running between farms dictated a bigger cab model, so we got the 5030 to go with our other smaller and bigger tractors, but I really like those tractors.
/ Orange Crush #51
My wife and I bought the L3540 after comparing it against the 3800. Probably not a fair comparison but we really like it. I would buy another one if I had to do it again.
No local dealers for Kioti, so I didn't consider that brand.
My Dad retired from JD after 35 years - he thinks the Kubota offers more bang for the buck then JD, but he's a little saddened that I don't have green in my shed.
/ Orange Crush #52
FWIW, I thought I was going "bigger" and really ended up with the same size tractor, only beefed up. Started with the L4300 4WD gear(which I still have) found it lacking on some jobs. Bought an MX5000 4WD gear and found it to be just the right size. Looking at it closely, it's just a beefed up L4300 with bigger tires and engine and a heavier front axle. Dimensions are nearly identical, neglecting the tires.
Having them both on hand is ideal. Not nearly as much implement switching. Plus the MX has extendable 3-pt. arms which makes hookups much easier (I'll never buy another tractor without 'em).
I think the MX5100's (updated MX5000) are available with HST, now. Might be a cost effective alternative to the L3540 if you ever think you'll need the extra HP.
/ Orange Crush #53
The Grand L 3540 HST-3 is a great sized tractor, and the 724 loader is quite powerful. Get the 72" HD round back bucket with the bolt on edge guard you won't be sorry, I just can't say enough about my L3540, great size tractor, oh also check on quick couplingso you can change bucket for front forks or what else you think you may need. Happy Tractor-ing!
DevilDog
/ Orange Crush #54
The Grand L 3540 HST-3 is a great sized tractor, and the 724 loader is quite powerful. Get the 72" HD round back bucket with the bolt on edge guard you won't be sorry, I just can't say enough about my L3540, great sizes tractor.
DevilDog
X2 on the heavy bucket with cutting edge and put some hooks on it too.:thumbsup:
/ Orange Crush
Thanks for the info. It does seem that the L4400/4600 and the MX series are probably the overall best bang for your buck. But I need to be pampered, absolutely HAVE to have tilt wheel, HST+, etc. :)
/ Orange Crush
DevilDog
Is the bolt on edge guard all that important? I don't like the way the bolts stick out the top. I also use my ratchet rake a lot; would the bolt on edge effect the ratchet rake fit? I guess the bolt-on will also bolt OFF if need be.
I will get quick attach. I didn't ask for it but my dealer pushed for it and he says he includes it at cost (I think he said around $300). It would be nice at least to be able to take the bucket off when mowing the yard.
/ Orange Crush
I desperately need hooks. Don't have em on my bucket now and I wish for them every time I move something big.
/ Orange Crush #59
You should talk to the dealer about putting them on before delivery, but be sure to specify how many and where to locate them as our dealer did not put them on our 8540 the way we wanted and my sons will have to move them or add a couple more as two are close the outside rather than in line with the lift arm and they didn't reinforce them so one is already bent.
I got some from Truck and Tow for my sons to put on our 5030 as soon as one of them can get caught up.
/ Orange Crush #60
I got my weld on grab hooks from Truck and Tow. 5/16" hooks fits 1/4, 5/16, and 3/8 chain. I put 5 on. With heavy duty round back bucket, no need to reinforce the welds. Philip.
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
1997 Take 3 Auto Transport Trailer Trailer, VIN # 1C9TT5036VB409167 (A61165)
1997 Take 3 Auto...
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
