Cut 10 acres with a pull behind?
/ Cut 10 acres with a pull behind? #1
jacobsdaddy06
NW Arkansas
MF1240
Just curious has anybody done this? At 60 inch cut would be the same as a 5' hog, previous pasture land no real obstacles, just don't have the funds right now for a tractor purchase, were saving for down to build the house? Thanks
/ Cut 10 acres with a pull behind? #2
so long as the ground is mostly smooth, no humps and bumps that will catch the mower deck, you should be fine. (watch out for them as a lot of pastures i know of have some bad bumps.) i have actually mowed parts of my horse pastures with a riding lawn mower. you might need to go a little slower then if you had a 5 ft bush hog as mowing grass shorter will take a bit more time to minimize some bumps. too fast could start bouncing and scalping depending on how yourr pull behind is set up and how close you cut it.
/ Cut 10 acres with a pull behind? #3
i asusme you are pulling this with an atv or rider mower?
just keep in mind it will not last as long as a tractor and mower.. IE.. finish cutting 10ac with the rider and trial mower will be a real workout... and a bit slow.
do you already have the trail mower and rider? if not, what is your budget?
reason I ask, is you can sometimes find a running antique with mower in the 1500-2500$ range... if you are spending 800$ on a rider and 800-1000 on a pull behind.. then you could get an old ford and 5' mower... maybee even cheaper..
just kicking out ideas.
/ Cut 10 acres with a pull behind? #4
Also the pull behinds are slow and do not give as good as a cut as tractor models. I mow a field every year because the guy says he gets a better cut than his trailed mower and he already owns it. He does do a few paths on his own. I have an old Ford N, available around here for a couple thousand with a bushhog, and it does a real good job and is useful for other tasks as well.
No don't Own the trail mower yet, have the atv though just trying to figure what's the best way to go with, thanks for all replies
/ Cut 10 acres with a pull behind? #6
Also think about renting a tractor and cutter, mow it with it and keep up with it, with the trail mower. a cheaper alt.
david
/ Cut 10 acres with a pull behind? #7
I mow 10 acres with a 5' rotary cutter and it takes forever. It was fun when I first started doing it, but after the 2nd time I was wishing for a larger cutter.
/ Cut 10 acres with a pull behind? #8
Renting a tractor and cutter would be your best bet.
/ Cut 10 acres with a pull behind? #9
I just got a flyer from DR. They make a pull behind rough cut mower. Only problem is is 44" wide.
/ Cut 10 acres with a pull behind? #10
problem with renting is it is inconvienient, either have to pay transport or transport yourself.. then you are pressed into a time frame to get it back due to renteal per day fee's adn if something comes up you either can't finish or must pay more to keep it.
after a few rentals.. he could buy a ford and 5' mower and be done with it.. probably for 2x what he's have in a trail mower.. he could get a good running tractor and mower that will cut whatever he needs.. and could sell it in a few years to upgrade, if needed, and not loose anything...
/ Cut 10 acres with a pull behind? #11
how long did it take you? i mow with a 5ft bush hog and do over 40 acres a year and on some pretty steep hills. i average just under an acre an hour. guessing you might be the same with your 10 acres= 10 hours? i guess it is all in how you want to spend your time. i can see if you don't enjoy mowing a bit it could get tiring.
/ Cut 10 acres with a pull behind? #12
when I used to cut my 10ac pasture with a ford * and 5' mower I was taking about 6 ish hours as I recall. but my land is flat ..
*( not usually an N.. but later , generally 00/01model.. though an N did mow it now and then..plus a few others.. and some later ones.. etc.)
/ Cut 10 acres with a pull behind? #13
You definitely could do it with a pull behind, but I'd agree with Soundguy-a vintage tractor and a 5' bush hog could be had for $3-4000, would be a heavier duty unit, and you would have a tractor for all the other uses you could find.
Will
thanks for all the replies, im gonna start looking out for that kind of setup, thanks
/ Cut 10 acres with a pull behind? #15
We used to cut 6 acres with a quad & 60" pull behind. Had to go slow for a nice cut. The quad would heat up so we parked it in shade a while then continued. IMO you could do it but will take time & expect some overheating.
/ Cut 10 acres with a pull behind? #16
I do 6 acres of flat hayfield in 3 hours with a 6-ft brush hog behind my 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD).
/ Cut 10 acres with a pull behind? #17
thanks soundguy and flusher. nice to have the comparison times. i use a kubota b7800 with fel to do my bush hogging. (5 ft bush hog) the tractor handles it great as far as just mowing. it does get tippy on the side hills i mow, so i have to go slower=57" wheel width (have to watch out for the occasional dip or woodchuck hole sideways on slopes that already make me feel uneasy. hit a hole unexpectedly and i would be going over). some i have to go straight up and back down repeatedly. some of the ground is rough so i go slow to not beat up the equipment. the just under an acre an hour is an average on all of it. i bet on the flatter and smoother areas i am very close to what you guys mentioned=around 2 acres an hour.
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
Tube Line Manure Spreader Nitro 275RS (A63688)
Tube Line Manure...
2013 VOLVO VNL 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2013 VOLVO VNL 6X4...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2018 Ford Focus (A61574)
2018 Ford Focus...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
