BX2200 HST oil foaming out dip stick hole
   / BX2200 HST oil foaming out dip stick hole #11
SUDT2 hydraulic oil is a Kubota branded product. It is usually only available at a dealership. It is quite expensive.
I ordered 4 gallons of Kubota super UDT2 from Coleman's tonight. I found a spec sheet for the oil and the numbers look a lot better than the conventional UDT oil. Especially during the first minutes on cold start up. Coleman's had a 10 % price cut on the case price plus their shipping to North Central Texas was about 1/2 that of Messicks. Coleman's shows to be in Kansas and I think Messicks is in PA. Its about 6 quarts more than I need right now but its a good idea to have some extra on hand in case a hose breaks and I need to top the system back off..
One other interesting thing about the super UDT2, the spec sheet showed there was a reduced amount of foaming compared to the conventional UTD oil.
Again thanks for all the input!!
   / BX2200 HST oil foaming out dip stick hole #16
I had the same problem with a B20. Water in the oil and air in the oil at start up. I did as advised above and changed the oil out with cheap hyd oil and then in a few months changed it out with Super Kubota.
The thing is I still had problems with air in the oil at start up. It happened only when the air temp was below 50. I kept the machine for several years and would just start it up and if the machine was not operating properly I would shut it off and let the oil settle. I think it had something to do with pump cavitation.
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
2020 CAT 308 (A53317)
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
