Tires B3200
/ B3200 #1
lastborn
Member
Clemson sc
Kubota B3200
If you load the R-4 tires on a B3200 how much weight does it add please?
I have used the search function to no avail.
Thanks
/ B3200 #2
You should have 15-19.5 tires on your B3200.
If that's the case, filling each tire should add about 29 gallons (if filled to ~75%).
How much weight depends on what you fill the tire with.......water weighs about 8.35 lbs per gallon, so that comes to about 250 lbs per tire.
/ B3200 #3
There are also several charts on this subject type in tractor tire fluild filling on Google. there are more in depth charts. Roy is correct though about the weight given your tires..
/ B3200 #4
The tire size is 12.4-16 for the R4's, not 15-19.5 as posted.
You are looking at a total of 375-415lbs extra weight depending on the solution. (187-207lb per tire)
/ B3200 #5
agree! (b7800 owner with same size tires)
/ B3200 #6
You could be right...I'm not a Kubota guy..
However, 12.4-16 are listed as R-1 Ag tires, not R-4's.
As 15-19.5 are one of the most used (if not the most used) R-4 sizes on compacts (not just Kubota), I made an assumption.
Correct me if I'm wrong, but please check the tire sidewall on you tractor first (if you have a B3200).
/ B3200
I checked. It is 12.4 x 16.
thanks
/ B3200 #11
Kubota uses the 12.4-16 size for both R4 and R1 tires on the B3200, I have a set of each for mine....
2021 Bobcat T66 R-Series (A64911)
2021 Bobcat T66...
2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
2024 Land Pride...
AGT 2 Post Car Lift (A64912)
AGT 2 Post Car...
Ez-Go Electric Golf Cart (A64912)
Ez-Go Electric...
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
