Options to get with HD rear blade
   / Options to get with HD rear blade #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I see multiple options for HD rear blades. Hydraulic angle, offset & tilt cylinders; cushsion valves; side/end plates; skid shoes; rear tail wheel. Any "must have"? Any not worth getting?
I am thinking Hydraulic angle and offset cylinders and skid shoes.
   / Options to get with HD rear blade #2
what size tractor?
Most of those options you mention only show up on something like this
but you need a 65-80HP tractor to make use of it.
what size tractor?
Number two in my signature. JD 6415 mfwd 85HP
   / Options to get with HD rear blade #5
I am thinking Hydraulic angle and offset cylinders and skid shoes.[/quote]
This is what I have on my Land Pride RBT45108.
I have Top and Tilt, so not as much of a need to get the hydraulic tilt on the blade. I have always had enough tilt with just the 3pt tilt cylinder. I do not have any need for the other options, but that is me with my own set of circumstances.
What model are you considering and how wide?
I liked the Bush hog, Landpride, Rhino and Woods. All rated for my 85hp or better. My target width was 8' but I found a 9' Bush Hog 121-09 used for a good price.
How much tilt can you get each way w/tilt lift link? The 121=09 only has an angle cylinder, but offset and tilt can be added.
   / Options to get with HD rear blade #7
Depends on your 3pt geometry, but some where between 10 & 15 degrees. Doesn't sound like much, but it is usually more than your tractor can pull in one cut anyway. Get that Bush hog if you can, that is a VERY good blade and the offset hydraulic is easily added.
   / Options to get with HD rear blade #8
End plates are a must in my book as they give you additional spoils management options.
   / Options to get with HD rear blade #10
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
Tree Boom (A50322)
Tree Boom (A50322)
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
