Options to get with HD rear blade
   / Options to get with HD rear blade #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I see multiple options for HD rear blades. Hydraulic angle, offset & tilt cylinders; cushsion valves; side/end plates; skid shoes; rear tail wheel. Any "must have"? Any not worth getting?
I am thinking Hydraulic angle and offset cylinders and skid shoes.
   / Options to get with HD rear blade #2
what size tractor?
Most of those options you mention only show up on something like this
but you need a 65-80HP tractor to make use of it.
what size tractor?
Number two in my signature. JD 6415 mfwd 85HP
   / Options to get with HD rear blade #5
I am thinking Hydraulic angle and offset cylinders and skid shoes.[/quote]
This is what I have on my Land Pride RBT45108.
I have Top and Tilt, so not as much of a need to get the hydraulic tilt on the blade. I have always had enough tilt with just the 3pt tilt cylinder. I do not have any need for the other options, but that is me with my own set of circumstances.
What model are you considering and how wide?
I liked the Bush hog, Landpride, Rhino and Woods. All rated for my 85hp or better. My target width was 8' but I found a 9' Bush Hog 121-09 used for a good price.
How much tilt can you get each way w/tilt lift link? The 121=09 only has an angle cylinder, but offset and tilt can be added.
   / Options to get with HD rear blade #7
Depends on your 3pt geometry, but some where between 10 & 15 degrees. Doesn't sound like much, but it is usually more than your tractor can pull in one cut anyway. Get that Bush hog if you can, that is a VERY good blade and the offset hydraulic is easily added.
   / Options to get with HD rear blade #8
End plates are a must in my book as they give you additional spoils management options.
   / Options to get with HD rear blade #10
YARD MACHINES MOWER (A50854)
YARD MACHINES...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
