Welding gas ripoff
/ Welding gas ripoff #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
I took my 80CF C25 bottle for a refill at Praxair. After I left I noticed that there was a sticker stating 69CF and the invoice said 70CF.
I guess Praxair can't get 80 CF in an 80CF bottle any more!
/ Welding gas ripoff #2
Was it filled to the proper psi? If so, it was properly filled.
/ Welding gas ripoff #4
The local dealer I use just swaps cylinders out. You pay a flat fee so there's nothing on the invoice to tell you how much you got. It's common practice to leave about 300 psi in a tank to avoid any air/ moisture getting into it. However I usually push it until empty because I'm in the middle of a project trying to finish.
Propane tanks for BBQ grills have a limiter built into them so you can no longer drain them empty. But some of the national companies like Amerigas are not filling the tanks up all the way. As far as I know that's only being done with propane.
/ Welding gas ripoff #5
I think that is a proper fill for that cylinder
/ Welding gas ripoff #6
Just purely a guess. I wonder if it was 69 to fill, in other words, the tank wasn't quite empty.
/ Welding gas ripoff #8
I am guessing that was full.. My brand new to me 150 cf tank only read 2000PSI when i got it from praxaire..
/ Welding gas ripoff #9
Yes, in general barbeque propane tank "swap out" is rip off any more. They only fill them 75% (16 lb) "to save you money":confused:
Ken
/ Welding gas ripoff #11
Ken
Ya need to be paying attention. :) For more than a decade now there has been a fed regulation requiring these bottles to be fitted with a OPD (overfill prevention devise) that limits tanks from being filled more than 80% capacity. You can not legally fill a bottle that doesn't have one of these valves. This applies to ALL DOT regulated bottles.
Tanks can be filled no more than 80% and that is the max you will pay for. No one is ripping off anyone.
Propane Tank OPD Valves
read bottom 2 paragraphs.
I think what he is saying is that a full bottle at 80% contains 20# of propane. They are only filling them to 16#, therefore the 75% fill of what the bottle SHOULD hold. OPD has nothing to do with this.
/ Welding gas ripoff #14
It indicated 2350 on the gauge. Don't know what pressure is normal.
That's in typical range. I'd have no problem accepting that pressure (and I've handled hundreds of cylinders when I ran a toolroom).
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
T/A Dovetail Flatbed Equipment Trailer (A66736)
T/A Dovetail...
Bomag Roller (A63689)
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
