cub lawn tractor backfiring?
/ cub lawn tractor backfiring? #1
liammulloy
Member
Craftsman LT1000
My neighbor has a mid 2000's cub lawn tractor and any time he mows the lawn and then turn the tractor off with the key...5 or so seconds...pop. I have been working on lawn tractors for a while but don't know why its doing this. He wants me to fix it, what should I check first? He says the sparks are new last year. Someone told him to kill it with the choke and that seams to work, but is that bad for the engine?
Liam
also its a kohler engine if that helps at all
/ cub lawn tractor backfiring? #3
Shut tractor off at half throttle. States this in owners manual.
is that b/c its a kohler, I have a b&s v twin and its never done this. Thought that is might be something with the muffler.
/ cub lawn tractor backfiring? #5
Sounds like enough fuel is left in the cylinder on shutdown to touch off after a brief soakback period.
Drifter2518's proposed half throttle fix makes me think this may be the cause and sounds like a very likely solution.
Give it a try and let us know if it works!
/ cub lawn tractor backfiring? #6
I currently have a Toro ZTR with a 15hp Kohler. The manual says to move the throttle between Fast and half throttle before turning off the key. The dealer says full throttle or at least 3/4 throttle. Now all my long life, I was accustomed to idling an engine before turning it off, but that's the wrong thing to do now-a-days. If you idle this engine and turn off the key, you almost immediately get a very loud, very severe pop. Lately, I've been sometimes (most, but not all the time) getting the delayed pop you described; 3 to 5 seconds after turning off the key. I just talked to my dealer about it day before yesterday. He says it will be the fuel shut-off solenoid sometimes sticking, but he also says it won't hurt anything (I'm not entirely convinced about that).
Incidentally, in 2004 I bought a Toro ZTR with a Briggs & Stratton engine. The solenoid never stuck on it, but you turned the key off at full throttle or you'd get a big enough pop to wonder if it would blow the muffler off.
So, my guess is that your friend's Cub Cadet has a faulty fuel shut-off solenoid.
don't know why but i can turn off mine at full/half/idle (or some combo of the 3) and have never gotten a backfire, idk. You know why? or which is better?
/ cub lawn tractor backfiring? #8
I'm sure not much of a small engine mechanic, so I can't say which is better. I preferred idling the engines before shutting them off. I think the idea of a fuel shut-off solenoid was to prevent the possibility of a carburetor float sticking and letting fuel either run out or run into the crankcase. But why it doesn't work at idle, I have no idea. I found and downloaded the Service Manual for my Kohler and to quote a small part of it:
Many engines are equipped with a fuel shut-off
solenoid installed in place of the bowl retaining screw
to eliminate back
firing when the engine is shut down.
If backfiring occurs on engines equipped with this
solenoid, verify that the correct shutdown procedure
is being used. In order for the solenoid to be e
ffective,
the engine must be running between half and full
throttle when the key is turned off. Next, check the
battery to ensure that it is not discharged or faulty. A
minimum of 7.3 volts DC is required to activate the
solenoid. Also check to see that the ground lead from
the carburetor body to the air cleaner base mounting
screw is properly connected.
CATERPILLAR 573C FELLER BUNCHER (A64276)
CATERPILLAR 573C...
Caterpillar Service Letters from 1960s and 1970s (A63117)
Caterpillar...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
2016 Ford F-450 Liftmoore 3200 1.5 Ton Crane Service Truck (A61573)
2016 Ford F-450...
2023 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59912)
2023 UTILITY VS2RA...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
