Seized Water Pump. Not happy
/ Seized Water Pump. Not happy #1
knightrider955
Lakeview, MI
Long 560
Fired up my Tractor for the first time this year. I heard a little squeeling sound but figured it just needed to be run from sitting outside all winter. All of the sudden there was a loud, continuos squeeling. I hopped off and looked only to find that my water pump wasnt turning. It is stuck solid. Funny thing is that usually when a water pump starts to go bad, it leaks. Not this one. Its bone dry. Never seen one sieze before. Ordered a new one. 85 Dollars!!!! Not a good start for the year. At least I was still in my driveway when it happened.
/ Seized Water Pump. Not happy #2
85 bucks! Sounds like a steal to me. Last one I bought was $380 and had a blame plastic impellar on it. Btw, mine locked up without leaking also. That was the first one I ever had do me that way.
/ Seized Water Pump. Not happy #3
$85 is a bargain......:thumbsup:
Wow Im suprised that 85 is a bargain. Especially since my tractor was made in Romania and its old. Well thats good to hear!! On a lighter note, this is the first time I have put any money into it. Would leaving it outside all winter have anything to do with the water pump siezing?
/ Seized Water Pump. Not happy #5
No it wouldnt.
/ Seized Water Pump. Not happy #6
Thank goodness you can still get parts. You should check your antifreeze, change it if over 5 years. It has lube in it for the pump. You can also just purchase water pump lube additive at any auto parts store. How long since your last service?
Ive never serviced it since Ive owned it, Im gonna put new antifreeze in it when I change the pump. Im also gonna change the oil and oil filter,
/ Seized Water Pump. Not happy #8
Can I suggest a new belt as well. Hate for charging failure or a overheat from a glazed belt after your labor.:)
Gary
Gary
I didnt even think of that!! Glad you said something!!! I'll order one today.
/ Seized Water Pump. Not happy #11
$85? - You did great!
The last water pump failure I had was on a 1968 Volvo 145S. When the bearing let go, the pump shaft, which was bolted to the fan, lost axial retention and shifted forward, augering into the radiator. So I had to get towed home, buy and install a new pump, fan and radiator. This was back in '79 and the cost to me was north of $400. Talk about not happy.
/ Seized Water Pump. Not happy #12
I had a water pump squeal for a couple weeks on my ole chevy truck. One day it stopped squeeling and set the belts on fire, before I could cut it off..some older Fords used to just shear the pump shaft and put the fan into the radiator..So really you did okay--on your rig....., I always used coolant, but the pump lube can go away, or become depleated..
Started taking the pump off. There is no room to work!! Im not happy with the design since there is a mile of room in front of the radiator. But zero room between the radiator and the pulleys. Im trying to do it without removing the radiator but this might not be possible. Had to remove the shroud just to get the fan off. I didnt save the coolent. Im gonna put new stuff in it.
/ Seized Water Pump. Not happy #14
If some of the radiator fins get folded from being brushed against you can use a fine tooth dog comb and sweep them gently out before putting shroud back on. Then air will flow through those areas.:)
Gary
Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
Land Pride RCF2072...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2018 VOLVO VNL780 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 VOLVO VNL780...
2017 John Deere R4030 (A64119)
2017 John Deere...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
Caterpillar Lift Truck Parts and Service Manuals (A63117)
Caterpillar Lift...
