PTO Clutch Issue
/ PTO Clutch Issue #1
cathyramey1966
Warsaw, IN
Cub Cadet LT1042
We changed blades and put everything back together. The mower deck engaged and then stopped working. We have checked wiring and the fuse. Still no luck. Any suggestions?
/ PTO Clutch Issue #2
the website's crystal ball is down - can you supply a bit more descriptive problem detail and machine model #.... and have you been using a garden hose or power washer to wash the machine?
/ PTO Clutch Issue #3
Its common early in the season that that one of the battery cells died over the winter and this will allow the blades/PTO to start but then quit without enough amperage from the system.
Most auto parts stroes will run a test on your battery to see if its holding a charge.
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
6' 3Pt Disk (A66285)
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2016 Volkswagen Jetta Sedan (A61569)
2016 Volkswagen...
Bobcat NB160 (A64127)
