Barn swallows... go somewhere else...
   / Barn swallows... go somewhere else... #1
riptides
Super Member
Northern Virginia
Kubota ZTR, RTV, MX6000
Well,
These past few months I have made a lot of progress on the inside of our old dairy barn.
Unfortunate over the years, we have had a lot of Barn Swallows make it their hatchery. While I do agree and like that they keep the insect population under control, I just cannot afford the time of cleanup required as they home in the barn.
I plan on shutting the barn off from them. I have removed most of the nests and plan on window treatments in the next few days, to seal it up. I still have not found a carpenter to make my my 22 plus windows that I need. Cost is too darn expensive for me. Time is too consuming for me to do it myself.
So, back to the Swallows, how can I encourage them to go elsewhere? I think they are genetically programmed to come to the barn.
Are there Barn Swallow houses available? Recomendations accepted and open to all suggestions, except firearms. :)
yeah... but...
Real world experience is here on TBN with a certain trust factor.
But thanks for the link. I may opt for another shelter outside the barn, but I will not be hanging chicken wire in my barn. :)
   / Barn swallows... go somewhere else... #4
I agree on the programmed comment to the point that they seem to come back to the exact spot. At my parents place they like to build nests on the window trim. Same exact spot each year.
I play this game with a robin each year. Last year, he moved on to plan B, then C D E... almost half way through the alphabet. :) You think he would pick a tree at some point but no. This year, he's back already, checking out the garage when I had the door open Saturday. We had a quick "chat" and he left. I've secured all last years locations and I'm going to try a motion detector/chirp alarm on a couple of new spots that can't be covered.
If chicken wire is too ugly, then maybe some of that black plastic netting. It's pretty much plastic chicken wire, but less visible.
   / Barn swallows... go somewhere else... #5
get yourself a birdguard Bird Control | Electronic Bird Control | Bird Gard
call them up and tell them what you want gone and they will put in the appropriate chips. You then set the speaker on top of your barn and useing the instructions set the volume and type of bird you want gone and say good by.
The bird gard is electronic (mine is for blueberry feilds jays, grackles, gold finches ect.) it lets out preditor sounds and scares away the unwanted without bothering your livestock.
I put mine on the 12volt power sorce that came with it insted of batterys, then set the dawn to dusk mode with 15 to 30 min intervals.
I cannot begin to tell you how impressed Iam with it and the cost is really reasonable
   / Barn swallows... go somewhere else... #6
For the windows buy some plexi-glass and screw it over the window holes if you aren't concerned about looks.
heheh.... you price plexi-glass lately?
The cheapest solution I have found so far is to build the windows to original specs.
42H 38w 9 pane glass.
Which I will probably have to do, cause it is labor intensive.
Interesting link. Thanks!
   / Barn swallows... go somewhere else... #9
You can get bird blocks at HD or lowes, they are reasonably cheap, and you would just have to nail them in. They work pretty good I use them in my garage.
   / Barn swallows... go somewhere else... #10
In our barn I found it easier to remove the existing glass (the panes fall out all the time) and replace it with a sheet of plexi-glass. I think it cost around $100 for a 4'x8' sheet here. That does about 5 or 6 windows depending on the size.
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
