Kuhn EL-35 Rototiller went SNAP!!
/ Kuhn EL-35 Rototiller went SNAP!! #1
variscora
Groton, MA
Allis-C 5050
Hi all...
Borrowed the neighbor's Kuhn today to test it in a little plot I will grow on this year, and when I hit a rock it went SNAP...
I assumed it was a shear bolt but when I started looking for the shear bolt...could not find it.
Can someone tell me, how badly did I mess up my neighbor's tiller? Is there a shear bolt and where is it so I can replace it?
Thanks much ahead of time.
/ Kuhn EL-35 Rototiller went SNAP!! #2
There should be a shear bolt on the tiller end of the PTO shaft. Turn the tiller by hand and see where it stops turning.
Thanks Massy...
Unfortunately, there is NOT a shear there. I thought there would be one too. The pto is intact and spinning and the plate that the pto attaches to spins freely...not sure what is going on in the rest of the tiller but the tiller splines surely are not turning.
Ugh.
/ Kuhn EL-35 Rototiller went SNAP!! #5
Kuhn implements are generally expensive......:)
Ohhh, that was cold! Is it a chain drive or gear drive? I would like in the cover over the chain to make sure the chain is still together. If gear drive you got me.
/ Kuhn EL-35 Rototiller went SNAP!! #6
What ever happened to this tiller? my dad has the same one that went snap. The shaft inside twisted in 2 and 3 gears had teeth missing. These things are over priced junk.
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
(4) Yetter Trash Wheels and Cutter (A65640)
(4) Yetter Trash...
2yd. Self Dumping Hopper (A65640)
2yd. Self Dumping...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
