putting teeth on a bucket
/ putting teeth on a bucket #1
Rio_Grande
I have a 72in viring finish bucket. I need to put a set of teeth on it, I concidered a tooth bar but the cost seems high for what they are. i have a single row of holes drilled in the bucket from the factory. I found teeth that bolt on but i would need to drill a second hole in the bucket.
My question is, are there manufactured teeth designed to be bolted on with one bolt and catch the edge to stay straight?
/ putting teeth on a bucket #2
I've only seen bolt on cutting edges, any teeth I have seen had to have a base welded in place.
Not saying they don't exist, just never seen single bolt on teeth.
/ putting teeth on a bucket #3
If you decide to weld go weld on, make sure you get the correct shanks. The shanks for a backhoe bucket are designed to go underneath, loader bucket shanks weld on top of the cutting edge, putting the tooth in line with the bottom of the bucket, keeping a flat surface for grading.
Ed
/ putting teeth on a bucket #4
If you find a tooth that fits your bucket and it has a hole that alliens up with the holes in you bucket then weld a piece of flat bar between each tooth so the teeth are conected and that will keep the teeth stright during diging.
I would not weld them to the bucket cause then when you dont want them you will not be able to take them off! :thumbsup:
/ putting teeth on a bucket #5
/ putting teeth on a bucket #6
Doesn't seem like you would use that for digging. Adding teeth to a bucket is for making it a better digger in hard ground. That looks more like a landscape surface tool.
/ putting teeth on a bucket #7
A toothbar may seem expensive until you see how much quicker you can grade and dig. I think that it's your best bet.
Correct you are. The Ratchet Rake is a handy tool and works great for the uses it was designed for (and a few more), but it's a terrible tool for digging. Throw in a little too much moisture and it's not effective for any kind of ground engagement except gravel.
Ordered a tooth bar today. 320, not too bad.
Tooth bar was exactly what the doctor ordered, it it awsome.
Jumper Cables (A64127)
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
YALE FORKLIFT (A63291)
(2) Liquor Barrels (A64127)
(2) Liquor Barrels...
2016 KENWORTH  W900 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH...
