Mowing B3200 go 60 or 72
/ B3200 go 60 or 72 #1
lastborn
Member
Clemson sc
Kubota B3200
Getting a B3200 Monday and can't decide if I need/want a 60 or 72 inch MMM?
Cutting 5 acres and most is sloped and has terraces and is bumpy { read not very smooth} For cutting along the terraces do I need the 60" or 72" MMM? I am worried about the side digging in on the low side. I know many here have a lot more experience than I.
need some advice quick please. I have a Woods RD72 and have concluded I don't like RFM"s.
Thanks
/ B3200 go 60 or 72 #2
I have a B3200 with 60" MMM and I wouldn't go any larger unless your ground is completely flat. Just my two cents.
/ B3200 go 60 or 72 #3
Thanks
5 acres is quite a bit to keep up with, especially when the grass is growing good. probably if it was rough like you say, i would go with the 60" as the 72" is just that much more weight to bounce around and more chance of scalping/digging in. 60" would be slightly more manuverable between rough bumps/etc.. why don't you like the rear finish mower? to me it would be easier to work on as you can easily lift up high to change/sharpen blades and it would be easier to detach when you want the mower off. also can lift it up a bit to go over the really rough areas to prevent digging in/scalping. you already have the rfm, do you want to spend $2300+ on a new mmm and bang it around on rough ground?
2020 Takeuchi TL10V2 Compact Track Loader Skid Steer (A66734)
2020 Takeuchi...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
2001 STERLING LT7500 SERIES (A67714)
2001 STERLING...
