Some questions about a 1997 F350 4x4 SRW Powerstroke
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #1
Lt CHEG
Upstate NY
New Holland T5.120
The other day I happened across a truck that it looks like I'll be buying. It's a 1997 F350 regular cab 4x4 with the 7.3 Powerstroke and a 5 speed stick. It also has a 8 foot Western minute mount plow. I saw it at a terrific deal (good enough price that I will let everyone know after I pick it up) and decided to take a look at it. The truck has new front fenders and doors and a junkyard bed. This was all done so that there was no rust on the body panels and then the previous owner shot it with some paint. It actually looks pretty good, but I'm mostly concerned that there isn't rust. The under carriage looks good. The engine seems pretty good and the transmission shifts well. The plow works well, but the moldboard is rough. I'll plan on welding a small patch and then painting the plow.
It's only an XL model, so no A/C and hand crank windows but the interior is also in decent shape except for the standard rip on the driver's side of the bench. It needs ball joints, so I am planning on just replacing the upper and lower ball joints on both sides. I also need to change the rear section of parking brake cable. I crawled under the truck and this really shouldn't be too bad as the truck is not rusty. How hard is changing the ball joints on this truck? Anything special to know about? How about the parking brake cable? What do you think a truck such as this would be worth?
I'm only planning on having this as a work truck. I'm still keeping my Silverado 2500 HD, and that will probably still handle any long range towing work. I'll probably use this for snow removal (it was cheaper than buying a snow blower for my tractor) and for towing my tractor around town as necessary. I'll definitely need to replace the hitch and I think I'll have to run wiring for trailer lights and brakes. It runs solid and only has 135,000 miles on it. The guy who currently owns it still drives it daily and I have no doubt that this will be a reliable truck as long as I drive it a little and take good care of it. I now have garage space for it and will be building our new place by the end of the year hopefully, so I can finally justify having an extra vehicle.
I'm actually looking forward to having a vehicle that I can tinker with. I'm also looking forward to having another diesel, and really happy that it is a pre emission 7.3 Powerstroke. I'm also pleased that it's a 5 speed so I'm not as concerned about transmission problems. Anything that I should know about this truck? Anything to look out for? I know about the oil pan issues on this truck and am fortunate that the previous owner changed the oil pan and the oil cooler within the last 2 years due to corrosion of the originals. I'll post more details when she's officially mine, but let's get the opinions rolling for now. Thanks in advance.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #2
other than the obvious issues from a upstate NY plow truck it is a great platform. Really check the frame/brackets/hangars for rust.... if the body rotted out who knows what the frame has been subjected to.
97-2002 were the best years for the 7.3 powerstroke owened a 2000 f250 myself kicking myself for trading for the 6.0 in 2003
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #3
Thinning, broken frame is usually what gets a plow truck. Make sure you look for any signs of welding and cracks.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #4
Check the front suspension as well..Those get hammered on plow trucks..Differentials/trannies etc also..Really depends on how it was used.
I brought a pair of coveralls so that I could crawl underneath and give it a good look. The frame didn't have any rust issues. I didn't see any cracking or anything either. I'll get a better idea of any issues related to the suspension when I replace the ball joints. I still feel confident that I could part the truck out for well over what I'm paying for it if things go really south. I'd have to believe that i could get at least $2,500 or so for the engine. A rust free box is worth some coin in Upstate NY too so between those two items I believe I could pay for the truck. Thank you for the suggestions I'll definitely be keeping an eye out.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #6
Before I sold it, I changed the ball joints in my '96 f250 PSD, and while you are in there, change out the u-joints. I learned the hard way. I bought the ball joint tool from Harbor Freight, with the Ford ball joint kit (two different items, same tool). I don't remember if I used the Ford kit on the '96, but the ball joint tool makes things a whole lot easier. My truck also had issues with glow plugs and relays. If you need to replace either, buy the motorcraft glow plugs. The autolites can swell and break off in the motor. The Napa relay is GPR-109, and if you go in there with that number, I think they are around $30. However, I was replacing it every year, sometimes twice a year until I bought a Stancore 586-902 relay from Mouser.com. It lasted two years until I sold the truck, and have had it in my '00 PSD for the last 6 years. They were around $50, but well worth it.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #7
I have had a number of 95-97 F350 PSD. The oil pan is a biggie. They all rust out and the motor needs to come out to replace it. Also as someone else said, if you are in there doing ball joints, do the universals as well. One of mt fuel rails went and that was a pricy fix as I remember. All in all those trucks are tanks and real work horses.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #8
Ah yes, forgot the oil pan issues. If there is wet staining on the outside of the pan, it is perforated. DO NOT probe with a screw driver, or you will go straight through.
Also brake and fuel lines prematurely rotted out on this era.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #9
I had a 99 XLT F350 that got totaled out about 3 years ago. Good strong truck but as mentioned the Ford front end required it to be maintained.
Plow trucks of all brands lead a rough life. Look over the radiator, oil pan, I joints, carrier bearing, drive shaft, brake lines, batteries and cables, ect.
Chris
Again, thanks for the advice, please keep it coming. As for this being a plow truck, I believe that this was not used as a plow truck for someone doing it commercially, rather I think this was someone's driveway plow. My reasoning for this is threefold. First off, it's got a stick and the plow is about the same age as the truck. Around here everyone who buys a truck to do commerical plowing, at least if they're buying it new, buys an automatic. An auto is just quicker if you're doing a lot of back and forth plowing, and when plowing time is money. Secondly there is no rust to speak of on the frame and the undercarriage looks pristine. My uncle who plows is meticulous about undercoating his truck multiple times per year and in washing it as soon as he's done plowing. Even his truck has some areas with more rust underneath than this truck. Lastly, the plow isn't in terrific shape. It's not bent and in fact structurally it is just about perfect. However, there are a couple of small rust spots on the top of the moldboard which is where rain and snow would land on a plow that sits outside. The rust is consistent with a plow that sat a lot and wasn't used that much. This all leads me to believe that it was someone's driveway plow and not a heavily used plow truck.
Nonetheless, I'm going to take every precaution with it. I'll plan on changing all the fluids and filters including engine oil and filter, fuel filter, front and rear differential oil, air filter and I'll likely change the brake fluid as well. I will change the upper and lower ball joints on both sides of the truck, and from the advice I've received so far, I might as well change the universal joints while I'm at it. I'm actually thinking of springing for the top of the line heavy duty ball joints that NAPA offers. They're almost 3 times as much as the standard ones, but since this truck will have a plow on it and be used as a plow truck, I think it might be worth the heaver duty ball joints. Does anyone have any opinions on the heavy duty premium NAPA ball joints? I will also plan on giving the truck a thorough washing inside and out, and will pressure wash the crap out of the undercarriage. I'll hit it with some undercoating now and will do so again before winter. Does it sound like I'm on the right track so far? Thanks
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #11
Personally, I wouldn't replace anything until it's needed...Some of the things you mentioned may have already been replaced..Why spend the money (I'm talking u-joints and suspension).
I would certainly go over all of the fluids though...General good practice on a used vehicle..
Sounds like a driveway plower to me...Every "for hire" truck I've seen has evidence everywhere.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #12
Besides the aforementioned oil pan and glow plug issues, only real trouble I had with mine(2001) was the HPOP, high pressure oil pump. It can cause hard/no start when bad.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #13
aside from what else has been mentioned, hit a store and have a spare CPS sensor and a 10mm wrench in the glove box. I have one in both of my 99 7.3's as insurance aainst needing to use them. actually bought a china stre wrench and taped it to the box and tossed in t he glove box..
I will probably see how the truck drives on the way home before purchasing u-joints for the truck. If it seems pretty decent on the longer drive to my house than I was able to drive it to test it out then I'll probably just leave the u-joints. It definitely needs ball joints though. They were noticeably bad on the test drive, and there's a bunch of play in them. The current owner (an auto mechanic by the way) said that he replaced the lower ball joints I believe, but the lowers are cheap enough that I'll just replace them both to be sure. Good u-joints are expensive enough that I'll likely keep the current ones if they seem okay. I'm also thinking of going with Moog ball joints from Rock Auto instead of the heavy duty NAPA's. They seem to be very good quality and also carry a lifetime warranty and they are half the price of the top of the line NAPA's. I've heard that MOOG makes good stuff, anyone have any negative opinions of them?
As far as the CPS, I'll definitely pick one of those up to have as a spare. I won't drive a truck much farther than around the block without some basic hand tools so keeping a 10mm wrench in the truck won't be a problem. Any other gremlins to worry about? I know that this generation of F350 isn't built as stout as the current generation, but everything still looks to be pretty well built and I'm guessing it should handle a 13,000 pound GVWR trailer about as well as my current 2500HD. I'm glad to hear you chime in as well Soundguy, as I know you're a big fan of the 7.3 Powerstroke.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #15
Cool..Seems you know far more about the truck than you let on....Moog does make good stuff......Carry on and good luck!!! Congrats.:drink:
Remember the TBN rule:...Without pictures, it never happened.:D
I can't go letting out all of my secrets. I haven't been able to pick the truck up yet and I don't want someone snatching it away from me. :D We had a verbal deal over the phone, but I don't want to take any chances. When I fill everyone in on the price, I'm hoping that everyone will see why.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #17
Me too!!!
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #18
I'd take a look at the cooling system as well. I bought my low mileage '97 F Super Duty 7.3 last summer out of PA.
While I've had no issues other than a bad vacuum pump, I did discover that it was full of orange antifreeze, probably DexCool type stuff. Not what it needed. So I flushed the system and used the proper coolant, pre charged with SCA from Tractor Supply. NAPA also carries an SCA supplement to add to coolant if it isn't at the right level. You'll need test strips to determine that.
The thermostat housings are known to be flimsy and a common leak point. Those can be had from NAPA. I also bought a stainless steel reinforcing ring for the housing from a guy on ebay. So far, so good with that setup.
I don't rack up tons of miles on this truck, as it's used seasonally for my seamless gutter biz. But just to save a little money I stocked up on some oil and fuel filters. I found some good spots online to buy them reasonably. I'd be glad to pass them along if anyone is interested.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #19
You need to run a coolant additive in that truck or the coolant will eat the block. The additive is available from ford. No one has mentioned the dual mass flywheel. If it goes you are looking at some serious money to replace it. Go with a aftermarket single mass flywheel. Way better. Truck that old, brake lines, fuel lines all probably gonna be shot or close to it. I had a 96 psd and the rust got the better of it. The engine takes 14 quarts of oil so beware.
/ Some questions about a 1997 F350 4x4 SRW Powerstroke #20
good point about the sca addatives!
soundguy
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
