p0peye
I have a leak coming from the inside bead around the rim. The rears are loaded with Rim guard and leaking . Is there a easy fix or do I have to take the tire to the dealer. I have r4s on my JD2520 .
I suspect you may not have had enough air on top of the RimGuard, which permitted a foreign object to wedge between the bead and the rim. Assuming over-pressure doesn't work, the fix may not be complicated. But is likely to be difficult because of the weight involved.Is there a easy fix or do I have to take the tire to the dealer.
The tire was very low on air pressure also so we put in 30lbs and will try it today to see if this helps. But if there is a leak around the bead why doesn't the air pressure force out the rim guard . Thanks for the replies.
Because the Rim Guard is not pressured sufficiently enough with the rather small area of air which is pressured. If it were high pressured, it would turn with the wheel.
You're joking - right?Because the Rim Guard is not pressured sufficiently enough with the rather small area of air which is pressured. If it were high pressured, it would turn with the wheel.
That doesn't make any sense -- what are you trying to say?
//greg//
I couldn't do it myself, my R4 rears probably weigh over 500# each. And I don't know if it could even be done safely with two people. But - with enough people and/or the right kind of equipment - the tire could laid flat with the leaking side facing up. If this puts the valve stem pointing at the ground, any remaining pressure should be released first. Once deflated and lying flat, the leaky rim seal should be broken. The remaining RimGuard will occupy the bottom 70% of the tire. The upper 30% will be an air pocket. This will permit you to reach in and clean the bead and the rim. Add air to reseat the bead, stand tire up, check for further leaking, reinstall if successful.
//greg//
In the context of the discussion, it cannot. Don't have a clue why arrow even wasted our time with this,
//greg//
You misunderstood my explanation, or perhaps you're thinking vertical. You can lay a tire down (horizontally) two ways; valve stem facing the ground (and therefore inaccessible), valve stem facing the sky. If you want to add air, the valve stem needs to be facing the sky. But I now see a fly in my ointment. If the rim leak is on the side of the rim opposite the valve stem, you can't do both.How can that work? If the valve stem is down to the floor and the leak is on top, once the leaky seal is fixed, how can you put air in the tire to reseat the bead?
I would think bad things would happen quickly by letting the air out of the tire standing up and then trying to lay it down with all that weight and no air pressure in the tire.
s219 said:I don't know what either of you clowns are talking about now. But since I work in fluid dynamics for a living, and both air and rimguard are fluids, I feel compelled to note that the lighter of two immiscible fluids in a vessel will always be on top here on earth where gravity points down.
At atmospheric pressure, yes. But you're ignoring compression. Air is compressible, liquids are generally not. When the air is sufficiently compressed, it can and will force a column of liquid against gravity. Same principle that makes air-hydraulic jacks work. My point was that - in the otherwise inexplicable example that arrow presented - it's not possible for a rubber tire to contain an amount of pressure sufficient to force RimGuard to the top. Not sure a tire actually represents a column anyway.I don't know what either of you clowns are talking about now. But since I work in fluid dynamics for a living, and both air and rimguard are fluids, I feel compelled to note that the lighter of two immiscible fluids in a vessel will always be on top here on earth where gravity points down.
