4WD on a lawn?
/ 4WD on a lawn? #1
Ginormous
Gold Member
Dayton, Ohio
Yanmar YM2210
Do you think 4WD would be particularly hard on a lawn, more so than 2WD? I have some hills, but my current 2WD does ok on them, so they're not too steep. If the grass is wet, I sometimes have to engage the locking differential.
/ 4WD on a lawn? #2
The only problem I could see is the agricultural tires and tight turns. I use R4's on mine and the front axle eats the lawn if I turn too sharply. My smaller tractor is 2wd with Ag's in the rear but still eats turf in the front when I turn too sharp.
/ 4WD on a lawn? #3
Engaged 4 wheel drive + agricultural tires + tight turns = chewed up yard. :mad:
Engaged 4 wheel drive + agricultural tires + gentle turns = smooth turf :thumbsup:
I have a YM2002D and mow with 2 wheel drive when at all possible. I do engage 4 wheel drive occasionally but only when really needed.
Turf tires would be the ideal thing but they are cost prohibitive for me plus I do a lot of gardening and I am doubtful I would get the same traction in loose dirt with the turf tires. My rears are also filled with a weak antifreeze solution and will tear up the ground quicker than before non filled.
/ 4WD on a lawn? #4
We use 4WD on all of our yards; no problem if use properly, ie engaged only when the traction is needed.
It doesn't sound as though you need 4WD if 2WD is working OK for you.
/ 4WD on a lawn? #5
Okay I use 4x4 all time and have the Titan turf tires. Don't turn hard or they will cut just like the single ribs on my old 2x ford...I pull a 62inch tiller with no wheel spin..32hp Bota.
/ 4WD on a lawn? #6
I never use it on my lawn its a flat 2+ acres but I think if I did need it and was out there using it that would cause me great suffering after she saw it. :D
/ 4WD on a lawn? #7
I use a freinds JD855. Its a yanmar painted green!! Its got 4wd and when i till the garden with it (only thing i use it for unless i need their loader) and they have the 4wd engaged when i borrow it (say they always leave it in 4wd) if i turn tight even the turf tires will chew the grass down slick under the front tires. IT looks about the same as if you spun out in your truck in the grass. just kind of burns it up and tears it down flat to the ground.
/ 4WD on a lawn? #8
4wd plays little to no part in what damage is done to a yard. It’s the tire design and turning radius that does it. I don’t think anything will tear up a yard more than ribbed front tires.
/ 4WD on a lawn? #9
Turning tight in 4wd will deffinitly tear up a yard, i have seen it. Like i said cause there turfs its not really a big deal to me as i have just what ever grows grass but if i had some fancy sod it would bother me. Same tractor turning same radius in 2wd does no damage.
/ 4WD on a lawn? #10
4wd plays little to no part in what damage is done to a yard. It痴 the tire design and turning radius that does it. I don稚 think anything will tear up a yard more than ribbed front tires.
I strongly disagree about the 4 wheel drive not playing much of a part. When turning sharply with any tires the front to rear differential difference causes the tire with least resistance to spin, in turn it chews up the grass.
If 4 wheel drive is not engaged the tires do not spin, therefore not near the damage.
I'm sure you are correct about the rib tires and I am not disagreeing with that.
I'm probably wrong but won't be the first time. :D
/ 4WD on a lawn? #11
Two other major factors to consider - How tight you try to turn and ground speed in the turn. Slow down and make a little wider turn for less tear out.:thumbsup:
/ 4WD on a lawn? #12
I should have said that I haven't noticed a difference. But, my soil is pretty hard to disturb, so I likely see less than other people with different soils.
/ 4WD on a lawn?
So, are you able to turn 4WD on/off as needed on Yanmars?
/ 4WD on a lawn? #16
I never take mine out of 4wd while mowing. I have areas that it will just slide down if not for the front wheel engine braking. I have ag tires, and unless the ground is very wet, does not to make much difference.
1500 gal Poly Tank (A66408)
1500 gal Poly Tank...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2013 John Deere 7200R Tractor (A66285)
2013 John Deere...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2011 WESTERNSTAR 4900 (A65643)
2011 WESTERNSTAR...
