Mowing Mower Options for JD 2750
/ Mower Options for JD 2750 #1
mcashman
Windsor, CT
TBD
I am in the process of purchasing a property and one of the things that comes with it is a JD 2750.
My understanding is that it has a 75hp PTO. Does this mean I have to buy some sort of gigantic mower / bush hog to be able to mow my pastures, or can I use something smaller (maybe 40hp)? It's my understanding I have to match the gearbox to the PTO - how close does the match have to be??
Thanks in advance for your help.
/ Mower Options for JD 2750 #2
All you wanted to know and more about the 2750 spec wise:
TractorData.com John Deere 2750 tractor information
75PTO HP means you can run anything up to 75PTO HP. Just beware, sometimes the lighter stuff isn't heavy duty enough to be playing with that much power and may be torn apart. You could run a large mower, but you don't have to. You could run a mower rated for 15PTO HP if you wanted.
Welcome to TBN!
/ Mower Options for JD 2750 #3
As Martian said, and if you go smaller then just be sure the slip clutch is adjusted properly or that the shear bolts are the correct size. You would be good to go then. :)
Thanks, all!
Many of the reasonably priced mowers seem to have 40-50 hp gearboxes. If I were to use such a mower with a 75 hp PTO, how do I keep the power within the recommended gearbox limit? Is it as simple as keeping the speed of the tractor low? Or is there some gearing associated with the PTO itself?
Thanks for your help!
- Mark
/ Mower Options for JD 2750 #5
You don't think the slip clutch would protect the gearbox? I would think it would.
Thank you all for being so helpful. It's good to know I don't necessarily have to have a six thousand dollar mower just because of the tractor size.
I'm just getting started with this, so your welcome and your advice is very much appreciated.
/ Mower Options for JD 2750 #7
You may not have to buy a large/heavy-duty mower for that tractor, but you'll be somewhat disapointed if you don't.
We have a JD 2550 (65hp) and use it with a JD 1008 bush hog, which is 10' wide pull-type. I've also tried a little 5' Kodiak brand cutter (40hp gearbox, shear pin), a 5' JD 513 cutter (60hp gearbox, slip clutch), and a 6' JD MX6 (75hp gear box, slip clutch.) The little Kodiak is what I use behind my Kubota and was pitiful behind the 2550. It would instantly break the shear pin in any type of heavy grass, and obviously wouldn't cover the wheel tracks. The JD 513 was better, still didn't cover the tracks, but it would hold up if you were careful with it. The MX6 is the only one that I'd say was really useable. It almost covered the wheel tracks and had had a big enough gearbox/clutch to handle moderate work.
Now, that being said, none of those compares to the 1008. It will take anything that tractor can throw at it and is more than twice as fast as any of the aforementioned. A medium duty 8' cutter, lift type, would also be a good fit. I personally don't like the 7' single spindle cutters because they are very long and cumbersome for the size (and often take more hp than the 8'). Bottom line, new or used, look for a bare minimum of a 6-7' medium-duty unit. A heavy-duty 8-10' would be better yet.
Here's the setup we use:
Kubota L4701 Tractor w/ Loader (A64047)
Kubota L4701...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
2022 Kubota MX5400HST (A64047)
2022 Kubota...
2017 INTERNATIONAL DURASTAR 4300 S/A 4X2 CAB AND CHASSIS (A59910)
2017 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
