Spreading Fertilizer with BX
/ Spreading Fertilizer with BX #1
Danner
Gold Member
Kubota BX2660
I need to fertilize about 5ac of fairly open pasture. This is a once, maybe twice, a year task. Will use my BX2660.
Would like some guidance on 3-point vs. pull behind, vs. receiver hitch electric (my BX has a sturdy 2" receiver on the draw-bar plate). If you could mention make & model that would help a lot.
I'm in Fort Worth, and would like to get something in the next week or so, as we are having great weather, and it would be good to build the turf while we have the moister.
Price is not a big concern, but I don't want to buy more than I need.
Thanks for your thoughts.
/ Spreading Fertilizer with BX #2
I think a three point spreader would be better than a pull behind. If you live close to a co-op and buy enough fertilizer from them they sometimes will let you use one of their spreaders for free or at a very low rental cost.
/ Spreading Fertilizer with BX #3
/ Spreading Fertilizer with BX #4
I've used a Ferguson Overseeder (Big rolling drum with spikes and bins for product to be dropped) and the funnel shaped spreaders on BXs. Both worked fine BUT fertilizer is the enemy of metal. The Ferguson is now only used for grass seed and I sold my funnel type fertilizer, I've gone to just mowing weeds and letting the grass clippings be my fertilizer.:)
Any way, the funnel type would be my recommendation on flat land or watch how much you fill it with. The shape causes the weight to get high and can tip a small tractor on a slope if it's full.
Always clean any of them that have any metal as soon as possible and then clean them again and maybe spray them with some type lubricant/sealer/protectant. I was surprised how quick the metal would start corroding after having the fertilizer in it.
/ Spreading Fertilizer with BX #5
Cleaning is so very important ... fertilize will eat it up in a hurry. When I don't use a buggy from the co-op and have to use the cone spreeader I always hose it off several times and then apply a light coat of a mix of used motor oil and diesel fuel ... seems to help.
/ Spreading Fertilizer with BX #6
Glad to see what your using. I think I sprayed mine once with WD40 since I had some but I don't think it was/is a good solution. It lubricates for a short period of time but I think it eventually goes away and then there the metal is shouting for corrosion to come on over and eat him/her up.:) Your solution should remain longer on the metal surface and maybe be a bit more afforable. Sure others have their own secret solutons that they may post of what does and doesn't work. But I believe several cleanings are essential and not just one hose off.
/ Spreading Fertilizer with BX #7
YES got to clean it after EACH use. I use a leaf blower 1st, then a hose, then leaf blower again, followed by WD 40, then hit the grease fittings . Blue River I like your idea of oil and diesel, I am going to "borrow" it.:thumbsup:
/ Spreading Fertilizer with BX #8
Coop is the way to go if you have one handy. Take a soil sample into them, they custom mix your fertilizer needs and put it in a spreader.
$25 dollars and return it. No worry about initial cost or cleaning.
/ Spreading Fertilizer with BX #9
Thanks guys ... I like the fact the mix stays on longer and clings to the parts. Then when you use it again the action of the unit sweeps it clean. I also use that mix on the grain drill ... on the inside after I have used the shop vac to clean out all the left over seed. BTW ... left over seed can and will germinate and grow inside the drill ... Then you'll have a real hard time digging it out.
Weed eater won't fit inside the grain box!!!!!!!!!!!!!!!
/ Spreading Fertilizer with BX #10
Does the CO-OP have a small spreader? The only one I have seen around here are the size of a gravity box and I would not want to use it with a BX.
/ Spreading Fertilizer with BX #11
True ... I can't believe they charge you !!! Here if we buy from them the spreader is no cost !!!
Its something how little things vary around the country.
/ Spreading Fertilizer with BX #12
I had a BX22 and my father has a BX23, 2 years ago I bought him a Polly 3 point spreader for Xmas. He used it to spread salt I. The winter and fert and Lyme in the summer. It works great. I will be using it to spread Lyme next weekend.
/ Spreading Fertilizer with BX #13
TSc has the 3 point poly on sale for 479 i believe. I looked at one and it was nice
/ Spreading Fertilizer with BX #14
I bought one of those pull behinds for spreading fertilizeer from TSC with wide turf tires behind my bx. Since I only have 2 acres, it doesnt take long at all and 5 acres is doable as long its a manicured lawn, not a field type. using a pull type in a field is just asking for trouble in a unstable bumpy field since its top heavy.
I attached a rope to pull the shutoff when I am in the seat since its too far away- so a 3pt might be a better option for you since the medium size one makes me refill 2 times for a 1 acre spread. 5 acres? You might be happier to fill once and be able to shut off/on from the seat with 3 pt spreader.
/ Spreading Fertilizer with BX #15
I'm getting a Country line sub compact 3 point spreader from Tractor Supply hopefully in a few more days ,been waiting now for over 3 weeks to come in.The sku # is 2120123 its on their website 400lbs max, not gonna put that much in it at a time probably 250 lbs. I only need to spread lime now . I PUSHED 500 lbs of fertilizer not gonna do that on 800 lbs lime!!!! Once I get it I will post some pics:D
/ Spreading Fertilizer with BX #16
Yeah, I agree...different policies depending on the area and store managers I am sure.
Deano
Thanks to all for your good information.
I must say, that Herd M-96 unit looks like it would be perfect. I'm gong to call the manufacturer and see if they have a Fort Worth dealer, or order one through UPS.
/ Spreading Fertilizer with BX #18
Like others, I purchased my 3ph spreader from TSC and it works great. Each year, I spread a couple of tons of lime and fertilizer on my horse pastures with my BX24. Cleaning and greasing after each use should keep it in working condition for a long time.
Thavil; thanks for posting that. Your storage building looks tucked and tight, well done. :thumbsup:
/ Spreading Fertilizer with BX #20
Thank you!! The storage building has a lot more "stuff" inside it now but the implements are still in the same location. Dollys really help out with saving room.
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2019 Toro...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2012 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
