LCD readout on BX24 - worthwhile replacing or not???
   / LCD readout on BX24 - worthwhile replacing or not??? #11
couldn't you just apply the 12V to it or pull the fuel pump and shutoff solenoid fuse and leave the key on for the number of hours you need to add? If might take a week to do, but possible this way I think..
maybe - but it just a PITA. :ashamed:
No, it will not come back once it is that far gone. Do you think it got moisture in it at one time?
After I got the new one from the dealer, I washed mine and it wound up with some condensation in it. I actually seperated the plastic and dried it out, then started removing it each time I wash it. I thought about adding a mechanical hour meter so I did not have to worry if it ever went out again. Never got that far though.
Deano
Not to resurrect an old item but just wanted to give an update: The readout cleared up and came back. Only thing I noted was that we didn't have any rain for about 3 weeks and wasn't necessarily that hot. Now that we've gotten rain for the past couple of days, it will be interesting to see the outcome. Unfortunately she sits outdoors :(
   / LCD readout on BX24 - worthwhile replacing or not??? #13
] Now that we've gotten rain for the past couple of days, it will be interesting to see the outcome. Unfortunately she sits outdoors
Can you secure a small tarp over the dash/steering wheel area to keep things dry?
   / LCD readout on BX24 - worthwhile replacing or not??? #14
Take it out and keep it in the house when not in use. They take about 10 seconds to remove. I take mine out when I wash it to prevent water causing the same thing.
Deano
   / LCD readout on BX24 - worthwhile replacing or not??? #15
Deano
:shocked::eek: ok . :laughing:
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
2013 Nissan Juke SUV (A50324)
2013 Nissan Juke...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
John Deere 980 Field Cultivator (A50514)
John Deere 980...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
