LCD readout on BX24 - worthwhile replacing or not???
   / LCD readout on BX24 - worthwhile replacing or not??? #11
couldn't you just apply the 12V to it or pull the fuel pump and shutoff solenoid fuse and leave the key on for the number of hours you need to add? If might take a week to do, but possible this way I think..
maybe - but it just a PITA. :ashamed:
No, it will not come back once it is that far gone. Do you think it got moisture in it at one time?
After I got the new one from the dealer, I washed mine and it wound up with some condensation in it. I actually seperated the plastic and dried it out, then started removing it each time I wash it. I thought about adding a mechanical hour meter so I did not have to worry if it ever went out again. Never got that far though.
Deano
Not to resurrect an old item but just wanted to give an update: The readout cleared up and came back. Only thing I noted was that we didn't have any rain for about 3 weeks and wasn't necessarily that hot. Now that we've gotten rain for the past couple of days, it will be interesting to see the outcome. Unfortunately she sits outdoors :(
   / LCD readout on BX24 - worthwhile replacing or not??? #13
] Now that we've gotten rain for the past couple of days, it will be interesting to see the outcome. Unfortunately she sits outdoors
Can you secure a small tarp over the dash/steering wheel area to keep things dry?
   / LCD readout on BX24 - worthwhile replacing or not??? #14
Take it out and keep it in the house when not in use. They take about 10 seconds to remove. I take mine out when I wash it to prevent water causing the same thing.
Deano
   / LCD readout on BX24 - worthwhile replacing or not??? #15
Deano
:shocked::eek: ok . :laughing:
INSPECTION (A51572)
INSPECTION (A51572)
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Kewanee 15' Disk (A50515)
Kewanee 15' Disk...
CASE 580M TURBO BACKHOE (A51242)
CASE 580M TURBO...
