SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,557
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
In that case you keep an eye on the tires at max rated inflation. If they squat too much take a hard look at the inflation info on the side wall. It will say something like: "MAX inflation 35 PSI when seating the beads" On my tires this is 20% above the rated pressure. Now, with the tire bead not seated, and therefore distorted, the tire integrity is relatively greatly threatened. If they think 20% over is safe then, imagine how safe it is when the tire is correctly seated. I have never needed to go above 30PSI on my 28 psi rated fronts, but I wouldnt hesitate to go to 35 or even 40 if I needed it. I once accidently filled one to 70 PSI with water. I would definitely NOT recommend, but it just goes to show what they will take.Did you ever check the load ratings on the FRONT R1s ?
They are typically NOT rated high enough for loader work.
Remember that whatever is in that bucket is cantilevered out 4 ft or more beyond the front axle, i.e. the front tires bear more than just the weight of the bucket and its contents, you can't go by the loader's lift capacity either.
It would be best to actually WEIGH the front end if you can, with a representative load.
To quote SPYDERLK in part:
"If you can do with the ground disturbance AGs are the way to go<snip>"
Where "ground disturbance" basically means they are likely to churn the ground up so badly that you will NEED them to get out of the ruts they cut.
Getting out of a pond with a blown out front tire is something I have no experience in, doubtless SOMEONE in this forum does and will be able to advise you on that when the time comes (-:
larry
