3 point hitch Draw Bar
/ 3 point hitch Draw Bar
Thanks for all the help guys. Your guidance has saved me from doing something dangerous. I am going to pull the pin on the draw bar(by the way didn't know you could do this until you told me) and extend it out far enough to hook up the trailer.
thanks
Damon
/ 3 point hitch Draw Bar #23
Thanks for posing your questions "damon c", I am fairly new to using a tractor and your post generated saftey issues that I may have created for myself. In particular the verticle movement of the 3pt under a trailer load - had not considered this, thanks "rambler" and "Baby Grand" for pointing out workable solutions and maybe saving me and my tractor from potential damage.
/ 3 point hitch Draw Bar #24
From the pic I'd say you are set up to pull just about anything :thumbsup:
I use the grapple hooks that you have on the crossbar as well, but mine are turned over to keep the chain in when it goes slack.
Thanks to the comments made here I'll find a way to strap the link down - just in case. These types of things are best done when not needed because usually when they are needed it's too late!
/ 3 point hitch Draw Bar #25
<snip>
You are welcome & that's why I like this place. Lots of ideas.
That's exactly how I found out - a heavy load shifted toward the back of the trailer while I was backing down a slight incline. This caused the front of the trailer to lift the 3pt up slightly. The increased incline caused the load to shift further aft and so on until it was against the tailgate. My bad for "failure to secure the load". I had to wrassle the load up the incline & secure it before I could continue.
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
2014 Mercedes Benz CLA 250 Sedan (A61574)
2014 Mercedes Benz...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
Caterpillar 955L Track Loader Service Manuals (A63117)
Caterpillar 955L...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
