Changing out wheels on spare axle question?
/ Changing out wheels on spare axle question? #11
It just occurred to me that I have a set of factory 15" mag wheels off a late 80's early 90's Chrysler I think Le Baron model, that are a direct replacement for you. I used them with snow tires on my 92 Caravan.
I also used the rear axle out of an '87 ?? Caravan for a trailer. I narrowed it a few inches so the springs would set directly on the old spring mounts. It was very simple. just cut a piece out of the middle, slipped the ends inside a larger pipe 3" I think and welded it back together.
/ Changing out wheels on spare axle question? #12
I agree with the load rating of 15 and 16" tires. I have a trailer with 5 x 4 1/2" pattern, and late 90s Dodge wheels fit. Unfortunately, these wheels don't fit on my old Coats tire machine because of the deep backset for disc brakes. I need 15" wheels designed for drum brakes that will hold LT tires--I load by volume, not weight. Truck load of feathers, truck load of rocks--all the same.
/ Changing out wheels on spare axle question? #13
on the coats center post tire machine, they have an adapter, for deep rims, a piece of square tubing that fits over the "Positioning Pin" and it has a tapered point in it that will hold the rim from spinning and extend the Positioning Pin that is built in,
looks like the name of it is, " Extension, Center Post Positioning Pin"
Positioning Pin Extension, Center Post | COATS Tire Changer Accessories
jsut an example below for a source,
http://www.ntxtools.com/network-tool-warehouse/CTS-104319.html
at one time they made two different lengths, only see one now, but use mine a lot on deep rims, or off set rims,
I would think one could make one reasonalble easy, that would work,
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
Land Pride SGCO554 (A60463)
Land Pride SGCO554...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2023 FREIGHTLINER M2 4X2 24FT SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
