$20 Chainsaw Tack
/ $20 Chainsaw Tack #1
Gale Hawkins
Super Star Member
Murray, KY
1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Digital Tach for tuning Stihl Chainsaw mini tachometer | eBay
Everyone said you need to make sure your saw is not running too lean and that one needs a tach to do it correctly.
The one above is actually over $40 but I bought the same one from Amazon for $20 with Prime shipping but was to lazy to log out so as not to show personal info. :)
It turned out the Stihl 361 was dead on idle wise and was OK on the high end but did hit 13,600 RPM but I did slow it down to about 13,200 RPM to be on the safe side and the engine did start to do a slight gurgle/motor boating but sawed just fine with no lost in power.
The 021 that I had bought new years ago was a different story. The idle was a tad high but the chain did not turn. 11,500 is the normal top end no load speed but it was only doing about 7,000 RPM so it really cuts much faster now.
For $20 it was worth it to make sure the saws were not too lean first of all then secondly not to rich.
/ $20 Chainsaw Tack
2005 Kawasaki STX-12F (A64127)
2005 Kawasaki...
Peanut Wagon (A64127)
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
2015 Kubota L6060 (A64126)
2015 Kubota L6060...
