carport project
   / carport project
I see. That's a lot of concrete. Looks nice, and the piers would keep the stone in place.
Here, because it's on an agricultural lot, there is no permit required. And because it sits down low, winds aren't too bad. Most of the wind goes right over my property at a fairly high altitude. But there is always a chance it could catch some wind (and certainly will). I do plan to use mobile home anchors and mine will be 10 feet shorter than yours. I see countless ones around here that are clearly just anchored in the dirt. Many have been there for years. If mine blows away.... oh well.
   / carport project #12
Gittyup - I am starting the exact same project and like yours, my area slopes quite a bit. Thing is, I'm not that efficient at grading with my tractor so its causing delays. I'm thinking about getting either a 24x26 or 24x24 with 10' foot walls. No sides though as I plan on closing it in with boards. It will look just like a pole barn and most of the framing is already provided. I got the idea from my neighbor who did this and you would never know it was a carport until you walked inside and saw the metal frame tubing.
Got any tips for excavating with a tractor? I have a FEL, Box blade, regular blade and a rake.
   / carport project #13
What should one expect to pay for a self supporting carport...I see ones along the road advertised for $595, but don't know what that might included or not.
I am guessing by the time you get what you want, the price goes right up...
   / carport project #14
That $595 one is a 12' X 20' X 5' frame w/21' roof length. I have been doing some pricing last week and found @ <www.carport.com> you can build and price your own and dealers in my local are all within a few $ of the same price.
   / carport project #15
Man that's really nice. How much did it cost minus the cement?
   / carport project
Dennis has it right. A basic carport, for cars is $600 to $700. It's real easy to figure cost, as has been pointed out, the retailers are all within a few dollars of each other. I'm planning on going with Carolina Carports. If you go to their website, there is a price estimator. I think it's pretty accurate after looking around and talking to sellers. I've costed mine, 20 x 26 x 9' gable style, 12 gauge frame upgrade, closed sides at about $2300. That's by far the cheapest structure I could build of this size that provides very good weather protection. It just for my trailer and backhoe attachment. Though I might mount a pallet rack under the back side and put my other ground implements on it. So, complete weather proofing isn't necessary. Kinda like that it's open and drive through.
   / carport project
I'm no expert. But, don't think you have to be. I simply drag my boxblade around until I have the dirt where I want it, setting the boxblade to dig where I want to dig and setting it to drop and level where I want to raise. A BB works great and only takes a bit to get the hang of. Take a few minutes to figure out at what lenghts the toplink must be set to to cause digging vs. leveling. After you know, that it's pretty simple. It does help to have a hydraulic toplink so you can make these changes on the fly without having to get off the tractor and screw in/out the TL. I also touch up and move around little piles of loose dirt with the loader. Just do it, what can it hurt? Dirt will move again if you get it wrong.
Good idea no using your own siding. I doubt it'll be cheaper than the steel unless you already have it. I think the cost for steel sides only adds about $180. But, if you use your own, you can get the look you want, which could be a big plus. If I decide the close the cables on mine, I might do that. This where they get ya. It's like $500 per end.
   / carport project
General Lee, Perhaps I could provide more information on the excavation for you, as I too was a little daunted at how to go about it initially. I don't claim that what I did was right nor the best, but I think the outcome is acceptable.
First I pullled the top soil off the high side and set it out of the way for reuse at the end. I did not disturb the earth on the low side. I then angled my box so that it set level while the tractor was setting across the slope long ways (tractor down/up hill side to side). With this angle I begain cutting across the slope at the high side pulling the dirt to the low end and down the hill at the end of the run. I repeated this until I had a "cliff" about 4' high (slope dependent) at the up hill side. Then I moved down to the next "row" and cut some off there in the same fashion. I then leveled my bb w.r.t. the tractor and pulled cross ways from uphill side to down hill side until the whole thing was about level. Occasionally when the piles were starting to build up on the low side I would switch the bb to leveling rather than cutting and smooth, spread and compact the down hill fill dirt. There were two shelves of shale rock that would not cut easily. For these, I used the teeth to break up, and then collected and move the loose material. Once I got it about where I wanted it, I then smoothed and leveled the whole work area using the bb by driving around all over, changing direction and approach several times.
After I had the area prepped, I then went above the cliff and starting cutting with my loader about 5 feet from the edge, pushing the cut dirt over the cliff. I repeated until the cliff became a slope. I then filled in and dressed it up with the top soil I had collected at the beginning. Then I compacted with the tractor, back dragged with the loader, and smoothed with the bb. Once I finished, I went to the bottom of the bank and cleaned up at the base. The end result was a slope gentle enough to mow across safely. I was even able to pull the bb across it sideways. My bank does have a slight hump in it because the shale runs through it and I was too lazy to break up the shale. I just decided it was good enough.
For drainage, as a last step, I tilted my bb up hill a little and cut in a few passes at the bottom of the slope so that water off the roof of the carport will flow away from the pad toward the bottom of the bank. I then made sure that this low spot sloped off longetudinally into the woods. The hope is that the water will collect in this slight culvert and flow off into the woods.
I have not dressed in the low side of the fill area of the pad. I'm going to wait for it to settle a bit first. After that, I plan to put in 2 truck loads of CnR where the carport will sit and the rest will get grass seed after raking.
   / carport project
Update. Got the stone today. Spread and leveled out to about 4 - 5". Is that thick enough? I laid down plastic first to keep the stone out of the dirt. Kioti action photos below.
   / carport project
A couple more. The rake let me get it nice and level. Got dark before I could take a photo of the finished surface. Now question is do I go for 6" thick?
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2018 MACK CHU613 DAYCAB (A58214)
2018 MACK CHU613...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
